Windows File/Directory comparison 'tool'
Discussion in 'Software' started by Abbo, 30 Aug 2012.
  1. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Hi
    I have a couple of NAS's at home. One for storing all files, and one acts as the backup to that. On top of this, I also have a RAID 5 setup on my PC for a third copy.
    The main NAS for storing files, decided to stop working, and for some reason the two other copies are out of sync with each other, so have had to use and update files on both locations.
    I am looking for a piece of software (or method) of comparing the two directories, and and highlighting the differences and also which has the newest files? I can then make one the master location and create backups from there.
    Any ideas?
    Thanks
  2. lp rob1
    lp rob1 Modder
    14 Jun 2010
    If running Linux you can use the diff utility, which shows the differences between two text files. It can be run on a whole set of directories where the file names are the same, and can also recurse into sub directories.
  3. Abbo
    Abbo ATi or Nvidia?
    11 Jun 2009
    Unfortunately not an option as using Win7.
  4. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Cygwin would allow you to use diff, as well as many other Linux commands, in Windows.
  5. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    It's a paid app, but BeyondCompare is pretty awesome for such jobs.
  6. azrael-
    azrael- I'm special...
    18 May 2008
    KDiff3 can do that, although it's main function is to compare source code revisions.
  7. Pookeyhead
    30 Jan 2004
    AllWaySync will keep your directories synced. It can do one way, and 2 way syncs, and either ignore or propagate deletions.
  8. mike_dowler
    mike_dowler What's a Dremel?
    17 Mar 2006
    I've used FreeFileSync before, and it worked well for me.
  9. steel_viking
    steel_viking What's a Dremel?
    6 Jun 2010
    +1 for FreeFileSync
