File recovery program?
Discussion in 'Tech Support' started by antiHero, 8 Sep 2008.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Hi everybody
    I had to reinstall a Laptop at work and forgot to take a backup of the Desktop files. I am now looking for a recovery program that can find the files even after format & reinstall if its even possible.
    Does anyone know a good program for that? Freeware preferred!
    Thanks
    antiHero
  2. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I've only ever used GetDataBack - which is quite expensive, so I can't vouch for any other program.
    There are certainly plenty of free file/data recovery programs available though, but rather than list a few individual ones you could try, just check them out for yourself ;)
  3. bullseye969
    bullseye969 What's a Dremel?
    8 Sep 2008
    GetDataBack saved my life literally last week when I forgot to back up my pictures when doing a reinstall <3
  4. antiHero
    19 Jan 2005
    I have been looking around on google myself but wanted to check if anyone here has a recommendation or something.
  5. Silver51
    Silver51 I cast flare!
    24 Jul 2006
  6. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    +1 for the expensive GetDataBack...
    also check out lifehacker (the site) - i think they did a top 5 on that kind of stuff the other day...
  7. spoon.uk
    spoon.uk Frag Me Bitch!
    1 Sep 2008
    Easy Recovery 6 always works for me :)
    But if you formatted and reinstalled OS on the same partition it might be a problem.
  8. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    I use Active @ Undelete at work and it works like a charm and it isn't too expensive. It can be found at http://www.active-undelete.com/ and it costs 39.99 US for a home user license.
    For a free solution, you can try http://undelete-plus.com/. I have used it and it is similar to the paid version above except it's free.
    As a suggestion, install/run the software from a memory key and recover your files to the memory key to avoid overwriting your files. I do this for any systems I need to recover and haven't had any problems.
    Monkeybone
