Build Advice File server build
Discussion in 'Hardware' started by Pookeyhead, 1 Jan 2010.
  1. Pookeyhead
    30 Jan 2004
    Ok... Just playing with Scan's website at the moment, trying to put together a file server with a balance between low power, and high disk performance.
    So far.
    Motherboard
    CPU
    RAM
    PSU
    RAID Controller
    3 of these in RAID5 (already have these)
    I'll stick it all in any crappy case I can find.
    Opinions?
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    CPU:
    Celeron E3200. - £35, dual core and more than enough power.
    RAM:
    Damn, memory is a lot more expensive than it used to be! Do you really need 4Gb? 2Gb would probably be just as good for the server.
    Everything else looks fine, but how do you plug those 3 SATA Drives into the controller? It only seems to have 1 SAS connection. Am I missing something?
  3. Pookeyhead
    30 Jan 2004
    There's an adaptor lead... just not sure whether it's included with it or not yet. Is has a SAS plug on one end, and 4x SATA on the other.
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    Good choices on everything, but the drives. DO NOT get anything that is a Green or Low Power drive, it causes faults when trying to access on a Raid. Those drives have a idle shutdown, and if you let it sit, and then try to access, it can cause faults and even total raid error. I'd go with some Samsung F3s. They are standard drives, but are probably the most economic in terms of both power consumption and raid safety.
    That one SAS port uses a break out cable that spilts to 4xSataII. Langer has the same type of card and the cable for it as well in his build, if you need an example.
  5. oasked
    24 Aug 2005
    Oh right, that makes sense. Shame the card costs more than the rest of the computer. :D
    What OS are you going to use?
  6. Pookeyhead
    30 Jan 2004
    Vista 64bit.. as I already have that. It's OEM and was used on this rig prior to Windows7, so I may need to make a phonecall to get it activated.
    Yeah.. I may get the celery instead of the Conroe. It's only a file server after all. Gonna do some research to see if 2GB will give me a performance hit or not. Shouldn't do I suppose.. but you never know.
  7. oasked
    24 Aug 2005
    Depends on how much money you want to spend really, I think both will provide similar performance.
    Having said that, if I was in your shoes I'd probably just spend the extra cash and get all the faster parts - just because. :)
  8. Pookeyhead
    30 Jan 2004
    I'm thinking the 450W PSU is overkill now. A celery with crappy onboard graphics and 3 hard drives can't need 450 watts surely.
  9. Unicorn
    25 Jul 2006
    Definately not Pook, get yourself something smaller but equally reliable. A 300W would do that I think. Do they even make PSUs that small nowadays? :hehe:
    The rest looks good, although what someone said about the Cav greens is worrying. Any proof that this is the case? Don't want your R5 array crashing because you were trying to save energy...
  10. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    I like it, should do the job. Guess you're wife has just killed you! lol!
  11. Unicorn
    25 Jul 2006
    He has an '06 'Stang, I'm guessing his wife is probably the coolest, most understanding lady in the world :D
  12. Fazed
    Fazed Minimodder
    5 Jul 2009
  13. Pookeyhead
    30 Jan 2004
    What dis someone say about Cav Greens? I missed that.
    Nah... she's all for it. We both have our entire lives on hard drives now - photos, music, video, work, documents.. the whole 9 yards.
    Indeed she is :)
    Right.... I'm now about to tear my hair out, because I've been reading that people using Intel's ICH9R onboard controller in RAID5 are getting write speeds of 120MB/Sec etc.
    If this is true, I'd rather do this than buy a £250 RAID card, especially as 125MB/Sec is the theoretical limit of my network anyway!
    I hate things that aren't simple.
    Still researching...Zzzzz.....
    Will report back.
    [EDIT]
    Check this out. Makes me seriously question why anyone would use a dedicated RAID card in a desktop environment.
  14. Burnout21
    9 Sep 2005
    here is an idea, get the basic setup and run the drives connected to the chipset and perform some benchmarking.
    Then if its ****, go for a RAID card.
    I also started looking at home servers, as i plan on swapping out my ubuntu OS on my server to windows home server, and in doing research i came across pre-built home servers.
    People might argue its cheaper to self build, but the pre-builders have done there research and got everything to function hassle free.
    Hp mediasmart server is one for example, i think this line of NAS servers are for people in your situation. Because you are kinda needing a small/medium buiness solution.
  15. oasked
    24 Aug 2005
    Hell, I forgot about Windows Home Server. Like Burnout21 said, you can buy pre-built boxes. Not sure how fast the I/O is though.
  16. Pookeyhead
    30 Jan 2004
    True... but I'd need at least a X38 Mobo to get ICH9R... and they're not cheap. If it turns out to be crap, then I still have to buy a RAID card... Grrr...
    I have nothing else to do today, so will carry on researching.
  17. Burnout21
    9 Sep 2005
  18. oasked
    24 Aug 2005
  19. Pookeyhead
    30 Jan 2004
    Damn.. there's an idea... Hmm... still.. it will take HOURS to build a 3TB RAID5, and even if it rocks.. it's not proof a ICH9R based server would work as well.
    Nearly £500 for 1TB is the answer :)
  20. Burnout21
    9 Sep 2005
    Plus your i7 920 would be doing the work load of shifting the files about.
