Build Advice File server build
Discussion in 'Hardware' started by Pookeyhead, 1 Jan 2010.
  1. Pookeyhead
    30 Jan 2004
    Well.. I've already run them in RAID5 in the NAS box. The other three are running quite happily in RAID5 as well. So I foresee no problems.
    The server is alive and well. It's installing Visat 64 Ultimate now.... slowly. Celery Cheesecake!!!
    Talking of which.... cheesecake always helps a headache :)
  2. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    good to hear pooky! benchmarks stat!
  3. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Well, that's good. Does RAID5 normally need identical drives, or not?
  4. Pookeyhead
    30 Jan 2004
    OK... been testing all morning (I feel asleep last night LOL).
    Not done any specific benches on the RAID yet.. except a few quick ones to establish it was working. I did a fast bench in both RAID0 and RAID5... just to see.
    RAID0 is around 450MB/sec read and 300MB/sec write. Which is cool.. but I need RAID5.
    RAID5 is around 250MB/sec read and around 175MB/sec write. So oodles of bandwidth for gigabit traffic there.
    I just copied a 80GB ghost image from my main rig to the new server's RAID over the network, and got this. (sorry about the weird screenie... I'm on teh server using MS Paint LOL)
    So the limiting factor is now the i7 rig's hard drive READ speed!! cool :) Basically, it means I can now back up over the network as fast as I could to the main rig's local drives.
    Mission accomplished.
    I will have to rebuild the server though... physically I mean... as this cheap case I bought has cooling so bad that within 10 minutes of operation the drives are at 50C!!!! Caught it just in time. I shall bring old faithful PC-70 out of retirement :)
    [ZOMG!!!111 EDIT]
    Just read that having matching figs for Jumbo frame support on all NICs across the netwprk can massively improve performace.. so I did.
    Same 80GB file from main rig to server over the gigabit...
    I think I can safely say that's as fast as I'll ever transfer files over a gigabit home network :)
  5. Burnout21
    9 Sep 2005
    loving that!
  6. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Matching figs? What do you mean by that?
    Oh and you do realise that you can crop the picture in MS Paint - no excuses for the massive white blank spaces!! :p
  7. Pookeyhead
    30 Jan 2004
    I can honestly say I've never used MS Paint before today LOL
    By matching figs, I mean in the netwok adaptor's config setings, you can enable, or disable jumbo frame support... which is basiocally large packet support. If enabled, it works better if all network adaptors on the network use the same figure.
  8. oasked
    24 Aug 2005
    Oh right, never gead of jumbo frame support - sounds like a wind-up. :D
    Where are the photos!? :)
  9. hughwi
    hughwi Minimodder
    23 Dec 2003
    Mission Accomplished?
  10. Guest-16
    Guest-16 Guest
    Looks great, Pook. Glad to see its sorted.
    Mind if I ask what your network switch is?
    Gigabyte GA-G31M-ES2L is Realtek GigE and what's your i7? P6T? That'll probably be Marvell.
    Just interested because my GigE switch is cheap and Im not sure if supports Jumbo Frames, or even if the Switch matters (iirc it does).. ill have a look later.
  11. Pookeyhead
    30 Jan 2004
    errr.. yeah :) Being able to write a back up to a server as fast as i can on the local disk :)
    D-Link DIR-655 is the router/switch.
    Photos soon... trying to configure a VNC now so I can run the server headless.
  12. Guest-16
    Guest-16 Guest
    Did you trim down Vista especially then? Or as is?
  13. Burnout21
    9 Sep 2005
    ultraVNC, get it and love it
  14. Guest-16
    Guest-16 Guest
    HippoRemote - control your server from your iphone or ipod touch :rock:
  15. Burnout21
    9 Sep 2005
    sounds like a headache as wireless VNC just fails.
  16. Pookeyhead
    30 Jan 2004
    Just as is.
    I'm trying tightVNC.. seems to work OK
  17. Burnout21
    9 Sep 2005
    so you've got all this in your PC-70, lol overkill much?
  18. Guest-16
    Guest-16 Guest
    It works great. Although thinking about it it's not applicable to this situation. Sorry :blush:
  19. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    why not just use remote desktop if your already running vista? thats what i use
    oh and for the screen shots type in 'snipping' into the vista run box ;)
    or alternatively use alt-prtscrn:)
    murtoz likes this.
  20. yakyb
    10 Oct 2006
    also copuld you get a power meter on it to see what power you are drawing My sig server pulls about 95W or ~ 105W with a few VMs turned on
