Electronics Filing/flattening the end of a LED
Discussion in 'Modding' started by craigbru, 12 Mar 2008.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    I've got a few LED's I need to file down, and I was wondering how much, is too much? (Obviously if I've hit wires, I've gone to far... :D)
  2. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    what end are you shaving down?? is this a problem that could be solved buy buying the proper led ie. square, rectangle, or smaller
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Basically, you've got it right. You can look inside the LED and see where the die and wires go, and you can remove just about all the material outside of that. Grab a handful of cheap LEDs and try it a few times to get the hang of it before you try it out on your good LEDs.
  4. craigbru
    28 Feb 2008
    Thanks for the responses guys. I've got a bunch of different LED's on the way, but the LED's I'm looking to file, are attached to a fan controller. As with anything, they could be replaced if needed, but I'd prefer to avoid it.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
  6. craigbru
    28 Feb 2008
  7. _-..zKiLLA..-_
    _-..zKiLLA..-_ What's a Dremel?
    8 Jan 2008
    wow thats awesome
    didn't know u could do that :D
