Cooling Fill position Q
Discussion in 'Hardware' started by coorz, 4 Jun 2005.
  1. coorz
    coorz Miffed
    25 Apr 2003
    Finally getting to play with my WC gear, now Q about where to use the T-line (DD fillport) to fill/bleed.
    Currently i've pre-setup the loop as follows:
    CPU>VGA>pump in>RAD>CPU
    So i was thinking to put the T-line after the RAD out. Because between the VGA>pump-in theres simply (small tight bend) no room to put the T-line.
    Will that work?
  2. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    i think that the t-line needs to go before the pump inlet, so the water can start goin round straight away!
    i was gonna put one out of my cpu bloke, but i was relaiably informed that that won't work!
  3. clocker
    clocker Shovel Ready
    21 Dec 2003
    The T-line is typically placed right before the pump inlet, because you DO NOT want to run the pump dry and this position is best suited to prevent this.
    You can however, place it anywhere in your loop...preferably at the highest point to aid bleeding...if you are willing to spend the time filling until the pump has been primed and you can energize it and finish off the process.
    Once your loop is filled and bled, the pump could care less where the t-line is located.
  4. coorz
    coorz Miffed
    25 Apr 2003
    I expect no problem with filling as i've build the loop externally, once filled and leak tested it'll go right in the case.
    Anyway i'll have a look into a different loop setup with some more room before the pump inlet. Thx so far.
  5. d0z
    d0z Minimodder
    1 Apr 2005
    I put my fill port in as a bleed to get air bubbles out of the system and also as an aesthetical thing :) i actually put mine after the reservoir, but it doesnt make much difference to what your trying to achieve.
  6. coorz
    coorz Miffed
    25 Apr 2003
    ok thx, already got it up and running. Didn't expect it to be THAT easy :).
    Had some doubts as the water was a tad troubled, too much zerex? But having it running for almost 2 days the water looks all cleared up now, the purple zerex gunk is now floating in the T-piece tube.
  7. Guest-6374
    Guest-6374 Guest
    You only need 1 part Xerex for 20 parts water, which is next to none. If you put in too much, just flush it and refill it.
  8. coorz
    coorz Miffed
    25 Apr 2003
    Water looks clear now, what would be the effect of too much zerex?
    I don't think i added too much anyway.
  9. Nexxo
    23 Oct 2001
    Too much Zerex may affect your temps a bit but that's all.
    If you have gunk, that is not due to the Zerex, but due to not flushing the components before you filled your loop. :D
  10. coorz
    coorz Miffed
    25 Apr 2003
    True, true i will next time, SIR :)
