im doing my first mod and i've had to remove lots of un need bits but the are holes in the case i would like to cover up then paint over or something anyone give me any ideas on what to use please?
Bondo body filler - most auto parts supply stores... Bondo, or its' equivalent, is fairly common in auto body repair, I would think. Most auto parts stores, or depatrment type store with auto supplies, would likely have it... Unfortunately, Bondos site doesn't list stores you could get it at....
yes definitely use bondo, but if your filling large holes (more than 1cm across or so) then youll need something for the bondo to stick to. i suggest taking a piece of thin metal or plastic (a leftover piece from where youve cut something out of the case is good) and glue it behind the hole, then bondo in the small indent and sand it flat, then repaint it.
Over here bondo has a funny name like P60, pop into halfors and look in the repair section, it in a black and red tub.
