Windows Film footage
Discussion in 'Software' started by bAnTAi, 10 Dec 2003.
  1. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    I've got some DV footage from my camcorder on my pc. I want to put it onto 1 cd, but with the maximum quality I can get, I.e a filesize of about 700mb. Can anyone recccomend a program that will do this? Divx codecs etc. are fine...
  2. white modder
    white modder What's a Dremel?
    19 Sep 2003
    dont know much about films etc...
    I would advice you to take a look at a specialised magazine
  3. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    im not sure if this helps, but i know a program called 'gordian knot' has a lot of divx/dvd encoding options so depending what your camcorder footage is saved as it may be useful.
    doom9 has guides for it i believe.
    im not sure if this will be helpful but hopefully it should be!
    RoB
  4. pranks7er
    pranks7er mange tout
    25 Dec 2002
    there is a dv editing software from adobe i think
  5. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    DivX or Xvid Codecs would come in handy here, they're good compressors and allow VERY good quality..
    I don't have the addresses so I'm afraid you'll have to do a google search. Use your preferred video editor to output it.
