Photos Film Scans
Discussion in 'Photography, Art & Design' started by IvanIvanovich, 14 Apr 2011.
  1. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I just got myself an OVT film scanner and here are some results
    various film stocks, speeds, lighting conditions and so on, to try and gauge what kind of results i can expect from it. these are raw scans without any contrast or color adjustments. they should be pretty close to quality but photobucket won't allow using the full size as i'm on free...
    so what do you think? decent or rubbish for film scans?
  2. Krikkit
    21 Jan 2003
    Have you not got prints to compare? How old is the film? Interested in this - looking at getting a print/slide scanner for a big pile of family photos now.
  3. IvanIvanovich
    31 Aug 2008
    the ones above are from a few months to 2 years old. i do have prints of those, but comparing to an image on a tn panel is pretty much useless.
    heres a scan of a negative that is probably around 30 years old
    grand dads vespa.
    one of the main reasons i got it as i'm planning on developing my own negatives from now on. an enlarger is prohibitive to me as i don't really have anywhere to put one. so i thought maybe a scanner would do the job. as a convenient way of getting from negative to something i can print.
    its the type of scanner you feed the film into, then it pulls it through taking a scan of each frame. it wasn't cheap, but not at the top either, about $300 but i figure in the long run i will save a bundle on processing as thats about the cost of 30 rolls.
  4. carpetmonster
    carpetmonster What's a Dremel?
    27 Jan 2011
    Chevrolet and Bar pics are fantastic. Some people spend ages trying to replicate that processing effect in digital.
