Actually that's a great idea. As reference Skorchio can find the dimensions for a GPU bracket I made for Metaversa in Jazzle's Sketchup collection. He can easily modify the design to include a hose separator.
Nice pic mate, and yes i can see a few improvements i can make so thanks Only thing i cant change the VRM tubing like that as the barbs are to long and i dont want to get new ones As for the graphics card idea, perfect, i was going to make a white backing plate so i can incorperate this in to it, i still have things to get laserd and powderd do this will go on the list!!! Thanks guys this its going to be awesome!!! And thats for all the kind words, it all comming together! Slowly hehe
Almost forgot, the floor only look so bright because of a lont shutter speed Ill take the next ones so it does not look so bright!
Ok guys i bought a new PSU today, as iv always wanted a moduler one so i can make new cables. Should be here soon
Time for another update, i worked on it last night and to night and its just been problem after problem (grrrrrr) Pics: Hmm where does all this go!!! Fist problem..... Once i got the flooring in (which is a frikin HUGE paint in the ass) one of the EL panels for the flooring stopped working, which made me mess my pants... So out it all had to come. Problem was one of the electrodes had broken due to the bending, bit of solder later and now it OK thank the lord i dont have to buy a new one, take all the fittings off and recut it! So flooring back in again then one of my fans stopps working... Anyone spot the problem? This is where i left it last night... Fast forward 24 hours... Time for some more money shots, please remember that side pannel is not the one im using its just to show how its going to look once i get the new side panels laserd! Then i go to fill sit up and boom one of my pumps is shorting some how!! This was after i have filled up the first loop so now i have to drain the whole thing, take EVERYTHING apart to get to the pump....... AAARRRGGGGGHHHHH Looked Frikking sweet with the fluids in it tho and the pump LEDS on but ill save them photos for next time. More soon. Skorch
Thanks for all the comments guys. May i ask who Murphy is? Took it all apart and sorted the pump, put it all back together again, all 3 loops filled... Leaky fitting on the 3rd... the only one i didnt fill up the last time, i knew i should have tested it to see if it was leaky before i took it all apart to fix the pump.. O well live and learn Looks frikking ace Filled up Teaser! (middle loop will be a lighter colour, i ran out of clear) More soon. Skorch
That always makes me wonder..... If you would try and proof Murphy's law. Would that go wrong too....?
