I really like the color scheme and the routing of the watercooling lines. Very well done and it makes the case look sweet.
Yes you probes could make the floor look White when offby putting some kind of film over it. The only problem is it would dull the light down a fair bit which is not very bright anyway. I might try hunting around for some special film, I wAs allways tempted to make the floor blue with blue gellio stuff Thanks for the other comments, tbh I still can't believe there are 3 loops in there!
finally getting nearly done nick... took your time shame you haven't got a white/black motherboard... pester asus/gigabyte to make you one xD
Thanks mate. Going to try and finish this weekend the. Take the bits to the coaters next week!!! Might be finished next weekend!!! And about time!
You have everything so clean that the side panel is almost a waste. ...but you have a cat, so I guess you need the panels.
Ye it is a shame but as the window is so big I hope it will be ok! The pumps are the only thing that make A noise so the side panel should block it out. I will try and upload a pic of it on the desk.
Your set up looks awesome man! the three fluid colours really do look quite fantastic when you see the case from a distance
Thanks buddy. I just took some HDR shots of the inside! I would go as far to say they actually do it justice!! Also been doing some more drawings today of my next mod Scratch build anyone? Skorch
Im looking to do something very similar but with a 24" and 2 19". Can i ask what stand you are using?
Loads of people ask me this but I really can't remember. I dint think you can get tripe stands for oven3x19" I has to add extra bars to mine so it would fit the 22 in the midlw. I would advise boluying a single one that uses a pole and make you own back plate from alli, that's what I would do going back.
Well after a long 19 months its final at a stage where I can say its finished for now. Hope you enjoy this small selection of photos, I plan to do a full write up very soon. All comments welcome Thanks Skorchio
This my friend is one seriously sexy build. It's so clean and tidy it's ridiculous. Every thing about it just works and flows so well. I'm actually lost for words , which is most unusual for me. This has to be in the line up for mod of the year. Top modding fella...+rep.
