Build Advice Final Approval
Discussion in 'Hardware' started by aidacuk, 21 Apr 2011.
  1. aidacuk
    aidacuk What's a Dremel?
    27 Mar 2011
    Hi,
    I asked about a month ago what sort of system I should be looking to build for £600. I had some great responses which helped me decide to go for an i5 Sandybridge build. I've now got to the point where I can start ordering the parts and before I do can you guys have a quick once over the below set-up to see if I can improve it anywhere?
    Motherboard - Gigabyte GA-P67A-UD3P-B3, Intel P67, S1155, PCI-E 2.0 (x16), DDR3 2133, SATA 6Gb/s/RAID, ATX - £126
    CPU - Intel Core i5 2500K Unlocked, 1155, Sdy Bridge, QuadCore, 3.3GHz, GPU 850Mhz, 6MB Cache, 95W, Retail - £160
    Graphics Card - 1GB EVGA GTX 460 SC Super, 3800MHz GDDR5, GPU 763MHz, ShaderClock 1526MHz, 336 Cores, DVI-I/MiniHDMI - £138
    Case + PSU - Coolermaster Elite 330 Black/Silver Midi Tower Case w/o PSU
    + 500W Ezcool PS-10 Silent, 80mm Fan, 24+4pin, ATX12 v2.03
    + Scan Vantager HR-221 All in 1 Flash Card Reader USB2 inc Adapterless for Flash PC/MAC - £32
    Hard Drive - 1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9ms, NCQ - £38
    RAM - 8GB (2x4GB) Corsair XMS3 DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-27, 1.65V - £69
    DVD RW - Sony DRU-880S, Black, 24x DVD±R, 12x DVD±DL, DVD+RW x8/-RW x6, RAM x12, SATA,Retail Labelflash - £19
    TOTAL - £582 (prices taken from Scans today only section)
    So I've got £20 left to play with. Anything I could/should change?
    Thanks
  2. Kaaa
    Kaaa What's a Dremel?
    22 May 2010
  3. Instagib
    Instagib Minimodder
    12 Mar 2010
    I wouldn't prod that with a 44 foot pole when under load.
    Spend some more to get a better PSU something like this.
    It might be less wattage, but its a name you can trust, and has a high efficiency rating. Surely others mentioned it in your last new build thread?
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    +1 for that, dodgy power supply is a no no, also I thoroughly recommend that corsair unit, its very quiet, with decent efficency as Instagib said, I've also just used one in a upgrade for my dad I've just finished, and he's very happy, much quieter than the cheap crap box that was in there before.
  5. trig
    trig god's little mistake
    10 Aug 2006
    never heard of that psu, and like instagib said, wouldn't touch it...grab the corsair he mentioned, any corsair, or xfx, seasonic, some antecs...check the sticky about psu's at the top of this forum...
    other than that I would look at how much of a difference there is price-wise between a stock gtx 560 and that 460. paying for a pre-oc'ed version of a card is like wiping ur rear with a $20 bill...
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    +1 on the better PSU. Not a place you want to cut corners. Rest of the build looks sound
  7. snooky32
    snooky32 What's a Dremel?
    29 Apr 2010
  8. KidMod-Southpaw
    28 Sep 2010
  9. aidacuk
    27 Mar 2011
    OK thanks guys. I'm going to go with the CPU cooler, and also buy a case and PSU seperate :thumb:
  10. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
