Can someone please tell me if all these devices are compatible, please. I would really appreciate it. MSI Neo4 Motherboard MSI K8N Neo4-F Socket 939 NVIDIA nForce4 ATX AMD Motherboard http://www.newegg.com/Product/Product.asp?Item=N82E16813130491 Price $69.99 AMD Athlon 64 X2 3800+ 2000MHz HT Socket 939 Dual Core Processor AMD Athlon 64 X2 3800+ Manchester 2000MHz HT 2 x 512KB L2 Cache Socket 939 Dual Core Processor http://www.newegg.com/Product/Product.asp?Item=N82E16819103562 Price $297.00 eVGA 7600GT eVGA 256-P2-N554-AX Geforce 7600GT 256MB GDDR3 PCI Express x16 Video Card http://www.newegg.com/Product/Produ...Go.x=16&Go.y=34 Price $169.99 with a $30 rebate $139.99 Patriot Signature Series 1GB kit (2 x 512MB) PC3200 DDR400 Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory http://www.newegg.com/Product/Product.asp?Item=N82E16820220037 Price $81.22 Antec TPII-550W Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply 115/230 V UL, TUV, CB, FCC CLASS B, CUL http://www.newegg.com/Product/Product.asp?Item=N82E16817103931 Price $83.99 with a $15 rebate Price $68.99 Aspire X-Navigator Case ASPIRE X-Navigator ATXA9N-BK/500 Black Steel ATX Full Tower Computer Case ATX 500W dual fan w/ automatic fan speed control. Connector 20 + 4 pin Power Supply http://www.newegg.com/Product/Product.asp?Item=N82E16811144164 Price $85.99 Sound Blaster X-Fi Platinum 7.1 PCI + bay Creative SOUND BLASTER X-Fi Platinum 7.1 Channels 24-bit 96KHz PCI Interface Sound Card http://www.newegg.com/Product/Product.asp?Item=N82E16829102190 Price $184.99 with a $30 reabe Price $154.99 Maxtor DiamondMax 10 250GB 3.5" Serial ATA150 Hard Drive Maxtor DiamondMax 10 6L250S0 250GB 7200 RPM 16MB Cache Serial ATA150 Hard Drive - OEM http://www.newegg.com/Product/Product.asp?Item=N82E16822144235 Price $74.99 Total Price $973.16 theoretically, are they all compatible and should they work?
None of the links work, this happens when you post a link from your cart/wishlist while you're logged in, for some reason newegg gives the items unique numbers or something (not sure exactly what but logging out and reloading the item page should give a good link). Also, if this is a final build I don't see any cd/dvd drives of any sort, unless you alredy have them that is.
24giovanni, you made a thread almost exactly this one yesterday. A new one was not needed. In future, try editing your threads, or even just responding to them.
hehe. Those links work, but I don't see much point in commenting any further, exactly the same stuff...
Giovanni: I've deleted your thread about this from yesterday. You're just posting a new wish list everytime you change your mind, and this is unneccessary, messy, and annoying. If you need to ammend that list, or get new advice, please just use THIS thread instead of making a new one. If you carry on making threads like this, I'll delete them. Just bump the old one instead.
