Build Advice final check
Discussion in 'Hardware' started by reme, 1 Dec 2008.
  1. reme
    reme What's a Dremel?
    1 Dec 2008
    Upgrading cpu,mobo,memory,video. Read several reviews and have these parts priced out. Going for a mid range (heavy) gaming system, budget is in around $650USD +- $60. Can someone reassure me before spending? Memory has never been my strong suite and overclocking is mildly important.
    Intel Core 2 Duo E8500 - $188
    GIGABYTE GA-EP45-UD3R - $109
    PNY XLR8 4GB DDR2 SDRAM DDR2 800 (PC2 6400) - $59.99
    Radeon HD 4870 1GB - $265
    Total is roughly $625.
    Appreciate any insight
    Side note, I am using my old systems psu, will this be fine?
    COOLMAX CXI-500B 500W
    Athena Power 4pin to 8pin Convertor Cable
    AND
    Seagate 7200.10 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    I would get an ASUS P5Q instead of a GIGABYTE GA-EP45-UD3R, what PSU are you looking at?
  3. reme
    1 Dec 2008
    What is the difference between all the Asus P5Q's? I notice there is a Premium/Deluxe/Pro/-EM/etc. Again, I probably won't be getting a second video card and overclocking is a plus but not my main objective. I just want a solid gaming system.
    I will be using the psu mentioned in the original post.
    Thanks.
  4. DorkSterr
    29 Nov 2008
    I havent been reading to much on the P5Q but their really good for ATI GPU's especially what you're doing right now, your PSU will have a hard time using all those components I would suggest a 600W+
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You might want to save some money by getting an E8400.
    Never heard of PNY RAM. I'd look into some else brand like Corsair, OCZ, G.Skill etc...
    Coolmax isn't exactly a good brand, I'd definitely ditch that PSU and get a new one. You really shouldn't skimp on the PSU as if it fails it'll usually take every other component with it. And old cheap PSUs are really not reliable.
    And no need for 600W+ PSU, a Corsair 520W should definitely do the job. :thumb:
  6. Guest-16
    Guest-16 Guest
    Why? :eyebrow:
