final decision on watercooling
Discussion in 'Hardware' started by f U z ! o N, 17 Oct 2004.
which choice? and please state why ( i dont care about low flow or high flow)
  1. choice 1
    26.7%
  2. choice 2
    73.3%
  1. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    i need to decide soon on my new watercooling.
    i have about 2 months to get my project done for schoola and i have a very busy schedule. therfore help my me decide
    watercooling 1
    polarflo tt cpu 3/8id
    polarflo tt chipset 3/8id
    polarflo tt vga 3/8id
    innovatek fass o matic with 3/8 barbs
    dual heatercore
    innovatek passive radiator with 3/8 barbs
    2 c systems pumps
    watercooling 2
    using stock tubing or 3/8
    aquacomputer cuplex evo
    aquacomputer chipset and gpu ( havent decided which ones i like)
    aquacomputer aquatube
    dual 120mm fan rad
    2 c-systems pump
    voltage regulator block
  2. Firehed
    15 Feb 2004
    1 - it's remarkably close to what I want to get and the polarflo blocks always seem to come out very near if not at the top in comparisons. Not to mention a set of three polarflo blocks direct from them is US$130 where it's almost that for the cuplex evo alone!
  3. f U z ! o N
    1 Feb 2004
    well i only want to go 3/8 because 1/2 is so damn big and i hate the looks of huge tubing all over the case so please anyone dont argue flow rates
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    iI clicked th ewrong one...
    I ordered a set of Polarflow blocks...amoung other things. They appear to be a pretty solid setup.
    (my thread is right below yours, have a look)
  5. Olly
    Olly What's a Dremel?
    21 Mar 2003
    I use AquaComputer gear in my rig and would highly recommend it ......
    Let's me get an 800 MHz overclock out of a 2.4c !
    Olly
  6. f U z ! o N
    1 Feb 2004
    so more research today about low flow and high flow watercooling. 3c differences is about the average. wow, i can live with 3c to avoid all that huge tubing. now mind you 3/8 is not that big. but the thing for the aquatube that sprays the water on the resevoir window is just awesome. not to mention the voltage reg cooler. now, my question is about those pushfits. do they do the same thing swiftech does by adding the hard piece inside the tube so the tubing holds better? grr decisions decisions. basically its go 3/8 with polarflo and switch the barbs on the innovatek passive rads or go aquacomputer 3/8 or smaller i hate decisions!
  7. Ligoman17
    Ligoman17 What's a Dremel?
    10 Dec 2003
    no "hard piece" you just push the tubing into the pushfit connector.
  8. Olly
    21 Mar 2003
    If you're going to use the Innovatek passive rad, just remember it was designed for 8mm systems, not 1/2" - it would probably give a lot of flow restriction in a 1/2" system.
  9. Risky
    Risky Modder
    10 Sep 2001
    Looking at the piece in question, it doesn't look that restrictive, but I'm only going on photos.
  10. f U z ! o N
    1 Feb 2004
    well i have made my decision. going the polarflo route but using dual loops with 2 C-Systems CSP 750 Mark II *BLACK* 12v DC Pump. the way the case is designed will be perfect for my watercooling because the processor will be like 6 inches from the radiator. awesome stuff.
