Build Advice Final i7 build what do you think?
Discussion in 'Hardware' started by bcooper56, 3 May 2009.
  1. bcooper56
    bcooper56 New Member
    3 May 2009
    I have been trying and i think this what im going to get this. tell me what you think? Also i plan to overclock cpu to 3.66 GHz think my pc could handle it and should i run modern games crysis, farcry 2 and dead space well? Any way here is the final set up im also getting monitor and such i should get in a few months since i don't have money yet but this is what i plan for.
    Case: CoolerMaster HAF 932
    PSU: Corsair CMPSU-1000w Power Supply
    CPU: ntel Core i7 920 ( Over clocking to 3.66 GHz)
    Fan: Coolermaster V8 CPU Cooling Fan
    GPU: GTX 295
    Mother Board: ASUS P6T Deluxe V2
    RAM: Corsair 6 GB [2 GB X3] DDR3-1600
    Monitor: Sceptre 24" LCD 16:9 Wide Screen HDTV Video & PC Monitor Support Resolution 1920x1200
    Drive: Sony 20X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive
    Key board: Logitech G15 Gaming Keyboard
    Mouse: Logitech G5 Gaming Laser Mouse
    OS: Microsoft Windows Vista Home Basic 64bit
    Total: $2,755.00
  2. bagman
    bagman Well-Known Member
    18 Apr 2009
    that set up sounds good but i am not sure about that monitor i would recomend the dell ultra sharp 2408Wfp
  3. Pookeyhead
    30 Jan 2004
    I'm a bit dubious about the monitor as well. Is there a reason you're going for a monitor/TV combo? Compromises like this are usually just that: A compromise.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Don't get Vista Home Basic, Home Premium is way better.
    Basic is too limited, for example no Aero in it.
  5. Guest-16
    Guest-16 Guest
    Fixed some of
  6. bcooper56
    3 May 2009
    What is Aero ?
  7. bcooper56
    3 May 2009
    Nice you made my pc shittyer so now i won't be able to max cryisis in 1920x 1200 with 8xaa
    *Face PLAM*
  8. bcooper56
    3 May 2009
    I chose monitor because it was cheap and need to save $$$ i could get good brand one but it would cost me 3000$ for pc
  9. samkiller42
    25 Apr 2006
    Bindi does some of the best hardware reviews on this site, and thus knows exactly what he is talking about.
    Sam
    Edit, just did a in game benchmark in Crysis at 1920*1200 with max graphics and 4x aa, and was getting a max of 14fps, so just goes to show you wont get what you want even if you spend on a 295, maybe get 2 260's.
  10. Guest-16
    Guest-16 Guest
    Well, I'm glad you appreciate other peoples efforts :rolleyes: Go for an expensive 295 then. It's SLI anyway, and GTX 260-216s are considerably cheaper.
    Considering you've asked "what is Aero", I think you're well out of your depth to be honest and don't know what you really want. You won't be able to Max Crysis at 8xAA with a single 295 anyway.
    http://www.bit-tech.net/hardware/graphics/2009/01/08/nvidia-geforce-gtx-295-quad-sli-review/9
    2xAA, Very High quality, DX10 = 34FPS.
    Turbotab likes this.
  11. bcooper56
    3 May 2009
    Alright my bad i think ill go with 2x 285 SLI i just read up on some benchmarks and it should do fine.
  12. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    +1 Don't know how you keep your cool, you must just be a damn decent chap.
    To the OP, just buy a ready made PC. With a **** attitude like yours, people will purposely offer you bad advice, to mess up your build, just to spite you.
  13. thehippoz
    thehippoz New Member
    19 Dec 2008
    soon to be part of the botnet XD
  14. Turbotab
    4 Feb 2009
    That's if the build is not buggered by plugging the 12v eps into the PCI-E 8 pin or some other gem!
  15. mm vr
    18 Nov 2007
    Aero is basically the new GUI what Vista offers... And that's not all you'd be lacking in Vista Basic.
    But yeah, get the 7 RC1, will be fine until summer 2010 or something and in October 2009 you can buy the full version.
  16. Snuffles
    Snuffles Dreamy Mammoth
    24 Feb 2009
    Wow Bindi, how do you keep your cool like that?
    BTW OP, listen to The Bindi, he just knows.
    Guest-16 likes this.
  17. bagman
    18 Apr 2009
    is there a rig that can take crysis max detail 1920x1200 AA8
  18. Turbotab
    4 Feb 2009
    Maybe 2 x GTX 295 in SLI and a heavily overclocked i7, even then the cards would probably be limited by video memory.
  19. Guest-16
    Guest-16 Guest
    Love you too (hug)
  20. Turbotab
    4 Feb 2009
    I showed you love in an earlier post, and you rejected me, the pain:hehe:
