Build Advice Final question. Honest. All in one water coolers?
Discussion in 'Hardware' started by dave99, 1 Apr 2011.
  1. dave99
    dave99 What's a Dremel?
    26 Jan 2011
    Are all in one water coolers any good? Was looking to use a Gelid Tranquillo to cool my Core I5 2500K but wondered if there was any advantage to using an Antec H20 620 or a Corsair H50?
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Performance isn't really better than the top air coolers, they cost more, and you lose a spot for intake/exhaust.
    ..You get to tell people that your system is watercooled!
  3. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    You don't need a high end cooler for a sandy bridge build. You should definitely replace the stock cooler for an overclock, but something mid-range or quiet is ok.
    Self contained water cooling is really convenient but not necessary. Air is fine for sandy bridge CPUs.
  4. dave99
    26 Jan 2011
    Just a passing thought. Think I will stick to the Tranquillo. Thanks:thumb:
  5. roosauce
    12 Feb 2010
    Cool. If you were building new then one of the ''Be Quiet!" range are in favour atm ... But no need here .. The tranquil is more than enough.
  6. dave99
    26 Jan 2011
    I am building new but the Bequiet Dark Rock Advanced specs says it is too tall for a define R3 case.
  7. bulldogjeff
    2 Mar 2010
    I've actually found that on an overclocked system, I get better temps with a H50 in push/pull config than I did with my titan.
  8. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    They are quieter though.
  9. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    my H50 has proven to be both quieter and slightly more effective than most high end air coolers that ive used.
    you dont have all the added stress of a huge chunk of metal levering against your motherboard.
    you have mounting flexibility. i got the h50 because the case its in is rather narrow and interference with the side fan was a concern.
    with the h50 acting as exhaust, all of the CPUs hot air is dumped directly outside of the case, lowering overall case temps.
  10. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    If you wanted to go down the water cooling seperates route you could check out ek's Pre made kits, they are very keenly priced
  11. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    If you move your machine about an all in one is good :)
  12. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    +1 for Tranquillo.
    Got it cooling a 2500k at 4.6Ghz currently. Doing folding as we speak and it sits at 58 degrees (23 degree air temp)
  13. GeorgeStorm
    16 Dec 2008
    I'm getting a H70 for my LAN its build I'm planning, tis good as a full air tower won't fit in the case, and obviously I'll be moving it about quite a bit.
