Build Advice Finally decided on a build (comments/advice?)
Discussion in 'Hardware' started by Stonerd, 8 Mar 2009.
  1. Stonerd
    Stonerd The monkey's out of the bottle, man
    1 Mar 2009
    So after a couple of weeks of deliberation and help from you guys at Bit-tech I've decided on my Core i7 build.
    ATCS 840
    i7 920
    Asus p6t mobo
    Corsair Dominator DDR3 1600
    NVIDIA 285 GTX
    edit: RS-850-ESBA - 850W Coolermaster Real Power M850 Modular PSU
    Thermalright Ultra 120 heatsink
    SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM
    any comments/advice?
  2. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Nothing except I wish I had the money to build a machine like that >.<
    Although you could consider going for a modular power supply. But that's all :)
    J/w, how much is the total cost?
  3. Stonerd
    1 Mar 2009
    with 22" samsung monitor, g9 mouse and g15 keyboard im lookin at about 1650-700 depending on where i buy things from.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    +1 for modular PSU. Check the Corsair HX620, should be plenty enough for that system. Or if you find Be Quiets in local shops you might get one of them.
  5. Stonerd
    1 Mar 2009
    thanks for the help, and yes the hx620 wouldve been enough for my system but i plan on OC'ing and SLI later, ill need that extra power eventually :D
  6. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Looks good. The only things that could be changed are the graphics card (a 4850X2 is much cheaper and is a faster cars) and the heatsink, to a HDT-S1284EE ans the associated mounting bracket.
  7. pimonserry
    20 Dec 2008
    http://www.frostytech.com/top5heatsinks.cfm
    Excellent heatsink reviews. Also, to get value-for-money, anything by Akasa or Xigmatek/OCZ (OCZ coolers are rebranded Xigmateks) will be fairly cheap and have good performance for the price.
    Also, if you're absolutely sure about SLI, then I'd say go for the modular HX1000 (unfortunately there isn't a model between 620W and 1000W) but it gets excellent reviews and I have a Corsair power supply and love it.
