Overclocking Finally Got My Phenom 940 OC Perfected
Discussion in 'Hardware' started by Madness_3d, 22 Aug 2009.
  1. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Having changed boards, I now have a Prime Stable Overclock that has some very nice numbers
    3.700Ghz
    264.3 Bus Speed
    14x Multiplier
    2.643Ghz Northbridge
    4228Mhz HT Link
    1056Mhz Ram 5-5-5-15-26 2T (unganged)
    1.54v VCORE
    1.65v HT
    2.93v VDDA
    1.62v VDDNB
    :rock:
    Under a Scythe Infinity (With 2x 1200rpm Fans) Hitting 70C (Core) Idling 50C
    Hoping to Get The Ram Running 1T
    Also Looking at setting up my own Dual Rad WC Loop
  2. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Nice work mate :D How long did it take you to get stable?
    Out of interest have you tried IntelBurnTest 64bit on maximum settings? Reason I ask is because im trying to get my other i7 920 rig 101% stable but am seeing silly 80c + temps at just 1.25v core @ just 3.8ghz :(
    It can easily do 4 hours+ on 64-bit version of Prime95 and on small ffts but after 10 mins on IntelBurnTest it fails, doh! :wallbash:
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    70C seems a real high temp for a 3.7ghz overlclock.
    I have my 955be at 3.616ghz and it never strays above 44c on the cores. I know 955's in general need less voltage but people with the same overclock on the AMD forums are no where near as high on temps as that.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  5. Madness_3d
    26 Apr 2009
    *secret*I Need a New Cooler :worried: *secret*
    Thing is the fans on my cooler are so low airflow that they barely cool it
    it didnt matter back when i had an Athlon 6000+ but now it makes a difference...
    Hoping as i said to sort out a WC loop at some point.
    I think the reason its that hot is because I was being overzealous with the voltages to get it prime stable. I tried lower and no it didnt help. Its taken me about 6 months betweeen motherboard RMA's and PSU problems. Thing is when the cooling isnt up to it Phenom II's dont like going fast and mine has been arguing past 3.6 Prime stable
