Graphics "find optomized frequencies" (Forceware drivers)
Discussion in 'Hardware' started by Bladestorm, 13 Mar 2006.
  1. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    How conservative/reliable is it ?
    7800GT, water-cooling, the auto-clocker in the nvidia control panel came up with 511/1222, which so far (not extensively tested yet mind) seems to run without a hitch, is that likely the max or is that going to be a ways under it ? :)
    Temp-wise, idle is about 31, highest load I've seen is 37 (according to rivatuner anyhow) need to find an app for the G15 that displays GPU temp ;) I've got one that can display temps from MBM if anyone knows of a mod or other way to get that to monitor it.
  2. Austin
    Austin Minimodder
    16 Jul 2004
    ;) It's a quick and easy way of doing it, I'd suggest dropping back 5mhz on both clocks but that's a good idea even when doing it the long & tedious way yourself.
  3. Bladestorm
    14 Dec 2005
    Yup, apparently too close, locked in BF2 after a few minutes, I'l let you know when I find the safe limit more accurately.
