Electronics Finding a battery, help
Discussion in 'Modding' started by Burnout21, 23 Mar 2009.
  1. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Ok
    Yesturday i found out my old Philips key006 MP3 player, and it wont charge at all, it has been sat doing nothing for a long time and i suspect the battery has gone dead completely.
    So i want to find a replacement, i have spent many hours searching for a replacement. Below i've snapped a picture of the current one.
    Dimensional space for it to fit in 36x17x6mm, its a 550mAh battery, but i must say i dont mind it being higher rated if possible.
    It might only be a 128mb mp3 player but its a magnesium alloy case and the design is so sleek, love it!
  2. jakenbake
    jakenbake full duplex
    5 Jun 2005
    no picture?
  3. Burnout21
    9 Sep 2005
    bit-tech is the host of the image.
    Infomation printed on the battery fot those who cant see the image..
    NT5M1A6V1Z 1.2v 550mAh I3 ( I think 'I3' is a revision number.)
    Googling the serial number dosen't result in much to be honest. And i am not sure of the internal chemistry of the battery, wether it be li-ion, or one of the nickel family.
  4. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    There's no picture. Is it round or square?
  5. Burnout21
    9 Sep 2005
    well if you look at the dimensions in the first post its rectrangular.
    Odd that i can see the picture, and this is the 3rd machine i've viewed it on.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    At 1.2V I doubt it's Lithium. If it's a Ni-Cad suffering from memory effect you can sometimes restore chargeability with a short sharp shock. Worked for me with a dud phone battery, a 1-second zap charge from a 12V car battery, then normal charge.
  7. jhanlon303
    7 Sep 2006
  8. Burnout21
    9 Sep 2005
    I found out a few days ago it was NiMH, and still searching for something suitable.
    I had a look and the album was set to private, so i have gone public in hope it fixes the problem of images.
  9. jhanlon303
    7 Sep 2006
    Picture works now.
    Try refining your search to "1.2V gumstick battery" lots of sizes
    john
  10. Burnout21
    9 Sep 2005
    think mine is a half gumstick battery, if that even exists....
  11. Burnout21
    9 Sep 2005
    haha, i finally found a battery which was ment for a cordless phone, two infact, two batteries doubled up for a 2.4v output, so i pulled out a soldering iron and dismantled it and rebuilt my MP3 it now charges and plays! yay!
  12. jhanlon303
    7 Sep 2006
    That's excellent! I totally spaced out cordless batteries. And I used to have my own Radio Shack store:wallbash: Good find.
    john
  13. Burnout21
    9 Sep 2005
    yeah it was a real B*tch to find, they are know by a few different names CP35, and HC something or other, most annoying.
    Anyway i kept finding them in packs of two, so i hunted for 2.4v battery packs, and i won! Cost me £10 from Maplin, F**king rip off tbh. Well at least i have a spare aswell.
    Again thanks john, your 'gumstick' search helped bucket loads!
