Development Finding a string in a text file
Discussion in 'Software' started by Sam0r, 12 Jun 2006.
  1. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Hi guys.
    I'm writing a PHP script to search through refferral logs from IIS/Apache and pull out all the google URLS and strip out the q=<text> part.
    Then I need it to output this to the user.
    How would I go about doing this? Currently I've got it to open the file and pop the contents into a variable, I can print this out fine.
    Cheers
  2. ajack
    ajack rox
    17 Apr 2003
    Use regexps, something like preg_grep() should sort ya.
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
    awk would be faster - man awk.
    Consider storing the results in a DB if they're big log files and/or the page will get lots of hits.
  4. eek
    eek CAMRA ***.
    23 Jan 2002
    Probably, however as he is using IIS I imagine he is using Windows so won't have awk.
  5. simon w
    3 Nov 2003
    I saw Apache and assumed access to Linux. No one runs Apache/PHP on Windows do they?
  6. eek
    eek CAMRA ***.
    23 Jan 2002
    I do for dev work :p ;)
  7. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    cygwin + awk
  8. Sam0r
    24 Jun 2005
    Its ok, we found a program do do it for us now!
    Thanks for the help though :)
