Windows finding computer ID
Discussion in 'Tech Support' started by Concrete-Coffin, 2 Dec 2012.
  1. Concrete-Coffin
    Concrete-Coffin Minimodder
    5 Apr 2010
    need a little bit help with getting computer ID my friend is trying to get this program see link
    http://www.op-com.hu/Codegen.aspx
    but im not sure which computer id he needs he is using xp on his laptop any help would be great sorry for lack of information
    tried this http://www.74mph.com/faq/FAQ00152.html
    but he says its not that got me stumped:wallbash:
    thanks
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Is there no licensing applications with the software? You may find a utility with the software that generates the computer ID.
    For example I use a software called CATIA for CAE at uni to get a license for it I needed to give my computer ID which a small utilty the software developer provides generates one based on my hardware. Kind of like DNA I guess.
    Here's what's used with the CATIA software http://rapidshare.com/files/4005279849/CatiaTargetID.exe
    You could try your luck and see if the code it generates works for you; they may use the same algorithm to generate it.
  3. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    According to the page: If you have any problem, or question using this page, please contact your distributor.
    Give who he bought it a call/e-mail they will be more help then us here i suspect
  4. Booti
    Booti Minimodder
    17 Jan 2011
    That looks something similar to what i have seen in a friends garage and he was issued with a USB serial key (basically your license key)
    He needed to input the USB serial key into a similar page to prove he had bought the software (as it was tied to his name and e-mail) before he could register the software and download updates.
    Does that help?
  5. Concrete-Coffin
    5 Apr 2010
    thanks for all the reply's think he got it sorted like i said didn't have a clue what he was trying to tell me over the phone abut conputer id
