Cooling Finding Fluorinert (aka PF-5080 aka FC-77)
Discussion in 'Hardware' started by airchie, 4 Feb 2006.
  1. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Hi folks,
    I'm looking to play about with some ideas I have for submersion cooling etc.
    What I want to use is fluorinert but I can't find anywhere in the UK who supplies it.
    I notice nexxo is using it in his rig and wondered if he, or anyone else here, could point me in the direction of somewhere to get it?
    Thanks in advance for any replies... :)
  2. Nexxo
    23 Oct 2001
  3. airchie
    22 Mar 2005
    Thanks nexxo, you're a star.
    What's the difference between FC-77 and the PF-5070 you linked to and the PF-5080 you use?
    I'm guessing just the boiling and pour points and other than that they're pretty much the same?
    Oh, and the cost obviously! :D
    Do they all have roughly the same dielectric strength?
    Lastly, is it safe to submerge a PSU in this PF5070?
    Sorry to be bombarding you with questions but I'm far from being a chemist and don't know what I'm looking at when I'm researching this stuff online... :(
    TIA :)
  4. Nexxo
    23 Oct 2001
    A useful reference is this:
    https://secure.serverroom.co.uk/ucommerce/shops/acota/shopdata/files/1405-200.pdf
    Look at one with a high thermal conductivity and low viscosity. I'd say FC-77 or FC-75 would do nicely as a replacement for PF-5080. Acota sells almost the whole range of Fluorinert.
    And yes, you can dunk your PSU in Fluorinert safely (--but only in Fluorinert. The trick doesn't work with FluidXP or MCT-5).
    Keep in mind that Fluorinert can only be used in a closed system, as otherwise it evaporates like crazy.
  5. stev
    stev What's a Dremel?
    11 Aug 2005
    Also, download the MSDS sheet and follow the safety requirements for this stuff. You don't need your neighbors or family to see the 6pm news of some guy passed out or critically ill from breathing the stuff in.
  6. Nexxo
    23 Oct 2001
    It's not that critical, as I can tell you from personal experience. Fill up the res in a well-ventilated area and don't smoke while doing so (the fumes are not toxic in themselves, but exposure to heat can change that). And of course don't leave the bottle or reservoir open when you're done.
  7. customh
    customh conflagration.
    22 Oct 2005
    Ill never know its nexxo now, his av is different.....
  8. Karel een
    Karel een What's a Dremel?
    9 Feb 2006
    Fluorinert source
    You can get the FC-77, PF-5080 type fluids from a reclaimer in the US at a much lower price than normal. Their website is www.tmcindustries.com
  9. Nexxo
    23 Oct 2001
  10. bizoth
    bizoth What's a Dremel?
    14 Sep 2009
    perfluorinated liquid immiscible with cyclohexane
    Dear well read FC specialist ,
    I'm prospecting for a perfluorinated (likely) solvent that would not mix with cyclohexane and yet could co-lyophilize with the latter or water : i.e. have MP BP close to 0 & 100°C.
    Would you have a suggestion ?
    Best regards from Brittany.
    Hervé
