Networks Finding out what is on the other end of an ethernet cable
Discussion in 'Hardware' started by OneSeventeen, 4 Jun 2007.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    In one of our undocumented wiring closets we've got a fiber optic converter going straight into the patch-bay. When I tested the patch bay with a basic patch cable tester it claimed the other end of the patch-bay was home to a computer (as opposed to networking hardware).
    So now I want to find that computer out of the 50 other computers in this building to see if it is still in use. (Without documentation, you run the risk of leaving things on that don't really need to be on anymore...)
    So I was wondering if I could just take my laptop in there with a crossover cable and run some script to probe the other machine to see what OS it is running, and perhaps what its IP address is.
    any tips?
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    You could probably just use a crossover and Look@Lan and see information about it. All you would need is just a clue of a range of the IP it's using.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Unplug it and see who complains :hehe:
  4. Glider
    Glider /dev/null
    2 Aug 2005
    This is about as effective as it gets...
    But a more hands on approach, do a portscan to see what is open on the PC/Server. Then you can use netcat or something to see what is behind each port, and figure out a use for the system.
  5. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Nmap has a host discovery thing which should tell you the sort of thing that is connected.. Just use a crossover cable, and one of the options that scans a large ip range, and leave it for a while.
  6. capnPedro
    11 Apr 2007
    Nmap or Firewalk, maybe.
  7. OneSeventeen
    3 Apr 2002
    Thanks, I'll just nmap it with a crossover cable.
    It was unplugged for about a day and nobody complained, which makes me think it is no longer in use, but is still turned on.
