Modding Finding these stuff...
Discussion in 'Modding' started by tsutton, 29 Aug 2003.
  1. tsutton
    tsutton Minimodder
    29 Aug 2003
    Okay, I need help with finding these stuff. Please remember, I am from UK, so all stores needs to be UK based.
    1) BIC Gel Intensity pens - I can't find it anywhere in UK shops and the BIC website only sells it as Trade, where you have to buy over 250 pens!
    Why you may ask. Well, I would like to do this - clickly click
    Unless... you know of any other pens that can do this? I am looking for Orange and Green pens.
    2) Window kit - 25x25cm or so. I know I can just pop in B&Q and get a large sheet, but I do not have any tool to cut it properly, I rather have a kit with the rubber tube. Does anyone know where I can get one for this size?
    The cheapest I found for 28x28cm with the rubber tube is £11.99 but it's out of stock and they don't know when they are getting more of them.
    Thanks guys & gals. :)
  2. AW3K
    AW3K What's a Dremel?
    3 Nov 2001
    Hiya i can point you in the direction of the pens,
    check out your nearest poundland, quid shop or what ever its called near you. they are sold in a big pack sommet like 10 pens for a £1
    Hope it helps
    AW3K
  3. tsutton
    tsutton Minimodder
    29 Aug 2003
    Cool, I didn't know Poundland sell them. :)
    Do you know the name of the pens on the label so I can find it easily?
    Many thanks.
  4. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Those are gel pens. Not exactly the same thing, but they'll work pretty well... They just take a little while to dry... Mostly any good fine point highlighter is UV reactive, I have a pack with 5 colors, and they are liquid pigment that work really well, they say zebra on them (but I don't know if they have them in the UK)
  5. AW3K
    3 Nov 2001
    They are sold in a huge flat plastic bord type thing with the pens spreed out in a fan shape
    Neon Gel pens or summet like it
    the make isn't shown on the pens and i threw away the pack, sorry
    As Pflumingo says they take for ever to dry.
    please let it dry b4 u power it up i'de hate to see ur hardware go pooooooof
    AW3K
  6. tsutton
    tsutton Minimodder
    29 Aug 2003
    Cheers for the info & tips.
    Now I need to find somewhere for the window kit...
  7. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Advent Plastics are fairly good for Perspex. They'll cut you a piece to whatever size you like and have various tint colours available in 3mm thick. They do other thicknesses too and are quite reasonably priced, just send them an email saying what you want.
    http://www.adventplastics.co.uk/
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    http://kustompcs.co.uk/product.php?view=2032
  9. tsutton
    tsutton Minimodder
    29 Aug 2003
  10. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    as no-one's done it yet.....
    welcome to the boards!!
  11. AW3K
    3 Nov 2001
    Oh yeah welcome to your new home, bit-tech.net, u'll never leave now.
    AW3K
  12. tsutton
    tsutton Minimodder
    29 Aug 2003
    Thanks for the welcome. I was a regular in TheOverclockingStore forum until they shut down. :(
  13. tsutton
    tsutton Minimodder
    29 Aug 2003
    I popped in my local Poundland store after work today and found two different type. So I got both of them anyway so I can compare which one is better.
    Wrote both set on a piece of paper and shined my UV light toward it.
    Some of them are great, but the best one is the package called "Rubber Grip Neon Gel Pens" (pink/purple package) as it glows even more than the "Neon Gel Pens" (blue and red package)
    I'll post the result of my case mod later on. :)
