Modding Fine Wooden USB (Update: May, 17)
Discussion in 'Modding' started by ./^\.Ace./^\., 19 Apr 2012.
  1. ./^\.Ace./^\.
    ./^\.Ace./^\. New Member
    7 Jun 2007
    So I was playing with my Dremel and ended up making a Memory Stick housing out of wood that I had laying around. I milled out a cavity for it and added some wood veneer to make it even nicer.
    This is my Third Memory Stick Mod.
    I keep forgeting to use my camera until after I make something cool, so here is the final picturs only.:duh:
    DSC01188 by Greg1001001, on Flickr
    DSC01182 by Greg1001001, on Flickr
    DSC01187 by Greg1001001, on Flickr
    DSC01185 by Greg1001001, on Flickr
    DSC01186 by Greg1001001, on Flickr
    DSC01184 by Greg1001001, on Flickr
    Scirocco and TaRkA DaHl like this.
  2. TaRkA DaHl
    TaRkA DaHl New Member
    15 Mar 2011
    Classy. I like.
  3. Plodder
    Plodder New Member
    14 Apr 2012
    Looks sort of japanese style, i really like it :thumb:
  4. 3lusive
    3lusive New Member
    5 Feb 2011
    Very, very nice.
    What colour's the LED light?
  5. Samrobmoe
    Samrobmoe New Member
    7 Apr 2012
    Wow, that looks amazing! Great finish! :clap:
  6. ./^\.Ace./^\.
    7 Jun 2007
    @ 3lusive - The LED is Green, The Memory Stick is a 16GB model that my Dad got for free.
  7. ./^\.Ace./^\.
    7 Jun 2007
    I have plans for another one as soon as I get the wood for it. I want to use something like Birds Eye Maple and something that looks like Tigers Stripes (lots of light and dark wavy lines).
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I LOVE BIRDS EYE MAPLE!!!!!!!!!!!!!!!!!!!!!!!!!!
    Any plans on a project log instead of pic of the finished project?
  9. ./^\.Ace./^\.
    7 Jun 2007
    @ The_Beast - Yes, next time I make one I will keep a log, It won't take long. This one only took me an hour and a half to make.
  10. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    Nice, clean, and simple; now that's a good USB stick. You've inspired me, and now I have a little project for some of the extra wood I have stacked in the garage. :thumb:
  11. The_Beast
    21 Apr 2007
    Nice, how are you going to finish the wood?
  12. ./^\.Ace./^\.
    7 Jun 2007
    @ The_Beast - The one I just did was sanded with 320 grit sand paper and has two coats of Danish Walnut Stain and three coats of paste wax, polished to a high shine (the wax was added after the pictures) and I'm sure I will do something like that again with the next one.
  13. The_Beast
    21 Apr 2007
    For the birds eye, I'd high gloss lacquer it
  14. ./^\.Ace./^\.
    7 Jun 2007
    It might be a wile before I make the next one, I'm not in a rush to go out and buy the nice wood for it. I might even just veneer a lesser piece of wood. I also know a Doll House store and they have tiny wood details that could look awesome.
  15. ./^\.Ace./^\.
    7 Jun 2007
    Ok, So I have started to gather the things I will need for my next Memory Stick Mod.
    I have desided to use Marquetry to decorate it. I have started to assemble panels for each side bit I need to get some inlay and some other Veneer so it will be a wile before there is an update.
    Here is a little taste.:D
    DSC01189 by Greg1001001, on Flickr
    This is the Veneer I used.
    DSC01190 by Greg1001001, on Flickr
    I printed out these chevrons that I made in AutoCAD.
    DSC01191 by Greg1001001, on Flickr
    They are quite small.
    DSC01192 by Greg1001001, on Flickr
    Here is both the front and Back parts, they are not done yet I need to make edges for them.
    DSC01193 by Greg1001001, on Flickr
    They were not easy to make and took like 3 Hours for each side.
    DSC01194 by Greg1001001, on Flickr
    Here is just a close up, they will look better after they are sanded and lacquered.
    I hope you like them, I will post more when I get the inlay.:D
  16. Cheapskate
    13 May 2007
    Nice. These are small enough to use semi-precious stone on too.:D *hint*
  17. ./^\.Ace./^\.
    7 Jun 2007
    @ Cheapskate - I don't have any, I think I will just use wood veneer with inlay on this memory stick.
  18. ./^\.Ace./^\.
    7 Jun 2007
    This Veneer looks good in the light after it is lacquered so the chevrons really pop and gives a great 3D cube effect. I'm edging it with a lighter wood to hilight it.
  19. ./^\.Ace./^\.
    7 Jun 2007
    May, 11 Update
    Last week I was in Washington D.C. and southern Virginia on vacation so I didn't get to start on the body untill this week and I also had a lot to do around the house.
    So I started cutting the wood for the body of the new Memory Stick today and I have new pictures.
    DSC01483 by Greg1001001, on Flickr
    DSC01488 by Greg1001001, on Flickr
    DSC01489 by Greg1001001, on Flickr
    DSC01492 by Greg1001001, on Flickr
    DSC01493 by Greg1001001, on Flickr
    The wood split a bit as I tryed to separate the two sides so I'm gluing the crack back together.
    Next I will use the Dremal to mill the two sides flat and then start carving out the inside cavity. The next pictures might be a wile as There is a lot of other work I need to do.
  20. ./^\.Ace./^\.
    7 Jun 2007
    May, 17 Update
    I have finished the construction of the new Memory Stick and have more pictures to share with you guys.
    I still need to pick a finish for it, ether lacquer or varnish or shellac.
    So that will be done at a later date.
    Here are the new pictures:
    DSC01495 by Greg1001001, on Flickr
    milling the wood flat.
    DSC01496 by Greg1001001, on Flickr
    DSC01501 by Greg1001001, on Flickr
    wood now milled out.
    DSC01503 by Greg1001001, on Flickr
    DSC01505 by Greg1001001, on Flickr
    DSC01506 by Greg1001001, on Flickr
    DSC01507 by Greg1001001, on Flickr
    DSC01508 by Greg1001001, on Flickr
    I used an ADATA 16GB USB 3.0 Memory Stick as this is going to be my main Memory Stick.
    DSC01509 by Greg1001001, on Flickr
    DSC01510 by Greg1001001, on Flickr
    Adding the side veneer.
    DSC01512 by Greg1001001, on Flickr
    DSC01513 by Greg1001001, on Flickr
    Adding the top veneer.
    DSC01515 by Greg1001001, on Flickr
    DSC01517 by Greg1001001, on Flickr
    Adding the bottom venner.
    Some finished pictures:
    DSC01530 by Greg1001001, on Flickr
    DSC01531 by Greg1001001, on Flickr
    DSC01532 by Greg1001001, on Flickr
    DSC01533 by Greg1001001, on Flickr
    DSC01534 by Greg1001001, on Flickr
    DSC01535 by Greg1001001, on Flickr
    I hope you've liked the project so far.
