Modding Finger guards required
Discussion in 'Modding' started by ouija, 26 Mar 2005.
  1. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    I'm considering using these fans for something, but I have no idea what for yet.
    I've no idea how much air they push, but comparing it to my old Delta 120mm they seem to be turning at least 7-8000rpm, maybe more. The blades are steel, so some grills might be required.
    So any ideas what to do with these sweet Papst fans? :p
    Some video clips (they're pretty much the same as each other):
    Movie 1
    Movie 2
    Movie 3
    Movie 4
  2. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Do a hoover pc! :hehe:
    EDIt: btw, where did you get them?
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Are those 240V Papsts? :eeek:
  4. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    build a floating pc :hip:
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Wow...build a freaking jet with em, they're loud enough for it :p
  6. ouija
    10 Nov 2002
    Yes they run off 230v AC :)
  7. Visionism
    Visionism What's a Dremel?
    24 Mar 2005
    Might??? :eeek:
    Put them on the bottom of a case, attach very low profile wheels, then when you're done posting on Bit-Tech you can push it around the yard and mow your lawn with it! :hehe:
  8. Leeum
    16 Feb 2004
    I can just see Ouija's next project log. How does Project: Flymo sound? :hehe: :lol:
  9. [Tom]
    [Tom] Minimodder
    10 Dec 2003
    I don't know, I can't hear it above the fans :hehe:
  10. ouija
    10 Nov 2002
    I might put them inside a "magic box" with a hole for you to put your hand in and find out what's inside :rock:
  11. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Doubt we would hear from ouija if he used those without guards. Kindof hard to type with no fingers. :hip: :eeek: But yeah, use them and then build in some lamp dimmers to control them. That would be pretty cool.
  12. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    Holy. Crap.
  13. tater salad
    tater salad What's a Dremel?
    26 Nov 2004
    thats what i thought
  14. ouija
    10 Nov 2002
    Maybe I could build two installs into a single custom case using these fans for cooling. *opens Sketchup*
  15. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Put a curtain on that bad boy and make a hovercraft! Better yet, put a pc on top of that, it'll be the first pc to walk on water ;p
  16. Isuo
    13 Oct 2004
    :read:
    Hehe...
    But TBH, a hoovercraft pc would be cool.
  17. Mattt
    Mattt Minimodder
    12 Nov 2001
    OMG
    where did you get these from??
  18. Atomic
    Atomic Gerwaff
    6 May 2002
    Old server would be my guess.
    I know some of the Alphas at work have mains supply fans in.
  19. Leeum
    16 Feb 2004
    I say you change career to a magician :D That way you can hold shows like Ouija and the myth of the floating box :hehe: :hip:
  20. fullymad
    fullymad What's a Dremel?
    27 Mar 2005
    hmm, i have been looking for some 120mm steel bladed fans for a mod im doing on my schools 2400 watt follow spotlight, surface temps get up to around 3-500 degrees so i need a metal fan to put in for some form of cooling. Any idea where they cane from?
