Modding FINISHED: Acrylic Case pics
Discussion in 'Modding' started by bee2643, 9 Apr 2002.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    allright, im done the case :D
    1 month, deep cuts, severed fingers, and one hell-of-a-rush later--i am finally finished :D
    this is the piece that i cut my finger off doing on the bandsaw, u can see 2 fan exhaust, i have no fan to cover the other hole, and i am grill-less for both holes.
    closeup of the fan
    the motherboard mounting and connections are shown here, aproxximately 1/4 of the way down the length of it there at the top is where my finger jumped off of my hand
    the infamous psu mounting, and yes, its supposed to be upside-down for specific reasons that i am unsure of yet.
    here is a closeup of the radiator vent, the grill will be put on at a later date, and then i will post pics
    here is a front-left shot of the case showing the drives and the 2 fans with their grills and the power/hdd activity LEDS that are barely visible above my power switch
    here is the front-right view showing the leds and power button more clearly
    here is the right-side view painly showing the liquid cooling system
    here is by far the best pic of my cold cathode hidden in there god knows where, but yea
    here is a top view of the psu, and once again, it is supposed to be upside down, im just not sure why at the moment.
    and finally, the top-right view of the case in the dfark with the cold cathode light beaming off its powers.
    any suggestions NOW?
    or perhaps some comments :D
  2. Randland
    Randland What's a Dremel?
    5 Feb 2002
    Looks cool:)
    A couple of suggestions
    1. "Window" etch
    2. Looks like you have a slight cable management problem. may want some spiral wrap/split loom
    Otherwise looks good:)
  3. Buck_Rogers25
    Buck_Rogers25 What's a Dremel?
    6 Feb 2002
    Yer Two.
    Apart from nice job obviously :) hehe.
    Dimensions for the case please 'and' the dimensions for your motherboard mounting, designing a case of my own right now and i really like the way you mounted that mobo, save me a lot of time if i could nick the measurements :). Would solve a hell of a lot of problems for me, considered the design but discarded it after realising i might run out of space but in yours theres plenty left, which comes back to dimensions please :).
  4. bee2643
    7 Mar 2002
    my psu came with plenty of extra cable wrap which i wrapped around ALL of the psu connectors, i have splitloom around every other wire in the case :/
    i plan on putting a megaman etch on as soon as i get $4 for the dremel bit
    oh yes, the dimensions
    18" wide x 18" deep x 14" tall
    the motherboard mounting process was SIMPLE, i simply un riveted an old backing from a case and stuck it in a slot that i cut out
    then i laid the mobo on the bottom lined up with the backplating and marked for the mounts
    then i used standard 1" motherboard mount and screwed into the holes that i marked and cut out with a rather small drill bit
    screwed the mobo on and it was all good.
  5. Buck_Rogers25
    6 Feb 2002
    Cheers very much m8, mobo mounting had been niggling at me, using a juno p6 for my main box now a nice swing out tray which im gonna have to lose i know. And theres little point in gutting this one just for a removable tray ill never be able to remove.
    Another issue sorted.
  6. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    all that work and you couldnt even get a good camera to take nice pics?:eyebrow: oh well, it looks awsome.
  7. bee2643
    7 Mar 2002
    rofl
    the camera is actually really nice, just its got this dial on the front to use for focusing, and it doesnt show the focusing thinger through the view, and so u can never tell if its perfect, it pisses me right thte hell off
    so stfu about my camera before u make me cry :cries:
  8. Tim S
    Tim S OG
    8 Nov 2001
    Nice looking case! :D
    A nice engraved window etch might look good on there, but its just a case of what the etch will be :dude:
    I think Im gonna get round to doing one myself too ;)
    On a more serious note: if you are being sarcastic, add a smiley to the end, such as a :) ;) :D or of course a :p .... it stops the person you aim the sarcasm at taking it the wrong way, thinking you are deadly serious. :D
  9. stewe151
    9 Mar 2002
    who was that ^ aimed at?
  10. bee2643
    7 Mar 2002
    well MY BAD BIGGIE :D
    hehehe
    anyways, ive got a megaman etch that im putting on the front:
    OMG
    I LOST MY JPG OF MEGAMAN
  11. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Nice cube.
    Did you happen to do any bending? I've read about heating it from a distance.
    I haven't seen anything regarding the protective sheet during the bending process.
    Are there any caveats there?
  12. bee2643
    7 Mar 2002
    define caveats, heh
    i did do some bending
    i made little 1.5" wide corner brackets out of plexiglass, they were just heated up along the middle with a hot wire, and then bent to a 90deg angle
    then bolted and glued onto the case
  13. kanuslupus
    10 Mar 2002
    Should the protective film stay on during the bending process?
    Is the protective film sensitive to heat, more than the acrylic/lexan itself?
    That is, if you get too close, will it melt at all and possibly stick to or do damage the acrylic?
    Or is it a matter of burning/damaging the protective layer will be enough to damage the acrylic?
  14. bee2643
    7 Mar 2002
    u should take the protextive film off, if u dont have a hot wire. then just hold it about 2cm off of your stove when its on medium untill u are able to bend it
  15. bee2643
    7 Mar 2002
  16. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I'm confused about something....with water cooling, why do you have sooo many fans in that thing? Also, i think your psu should be turned around, the fan you have on top is meant to be an intake, to suck air from below it and blow it out the back. Hvant checked out the new pics yet, but i'm getting ready to 8)
  17. bee2643
    7 Mar 2002
    :worried:
    as u can see i cut it out backwards, heh, i was hoping noone would notice but MY BAD ;)
    ia have all the fans in there because allthough my cpu runs at 20C, my mobo runs at 28C, and my videocard at 35C, and my videocard doesnt have a fan on it, so yea, it kinda broke when i decided that it would be more convienient to run it fof a molex....i guess it wasnt the average 12V fan :/
    heh, anyways, i also have a uncooled maxtor 40gb 7200rpm drive and it gets toasty, AND, my CDBURNER, which i recently raped its fan from because it got too noisey from me, is also running too hot
    like i said in the earlier post ^^ http://66.183.21.94:3000/fileserver/finished_Case/digital/ to see more pics of the case taken with a digital camera, it also includes more detailed and zoomed in photographs
  18. stewe151
    9 Mar 2002
    thats allright, mine is stiiting on the floor about 1 ft from the comp:D
  19. bee2643
    7 Mar 2002
    bah, this is teh worst mod ive ever done
    i cant believe what a piece of $$$$ it is, seriously
    you want me to point out the flaws with this jewbagel?
    1) i cant screw the expansion slots in because the plexiglass is too thick
    2) the cdroms are alligned on the back of the case because their too big to fit through, and widening the whole wont cut it
    3)the psu is upside down
    4) im scared ****less to stick a vacuum in my case to clean it up from the dremel
    5) i have NO idea why, i used the same glueing methods as linear, but when i move the case the whole thing cracks as if its about to collapse on itself
    6) the motherboard isnt even mounted in
    7) if you move the case the peripheral cards either come out, or short the psu out,
    8) the top cover doesnt line up PERFECTLY, and i have no way of mountin it on mbecause my poor-4$$ cant afford thumbscrews
    9) because i feel that there should be a 9th point
  20. brutal
    brutal What's a Dremel?
    7 Nov 2001
    bee this isnt a criticism cause my hands shake too thx to mountain dew. get a 5 dollar tripod for your camera, the pictures will be a ton clearer :D
    btw nice work
