[Finished and sold..] Project: ???(unnamed)
Discussion in 'Project Logs' started by Jokkocze, 22 Dec 2004.
  1. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Hey peeps!
    I'll get my cheapo case tomorrow, and after xmas, I'm gonna start modding it!
    The case is a unknown model from Sweex (it was really cheap! just 12 quid!), that looks like this:
    Anyone got any ideas what I can do with it? I'm thinking of removing all weird stuff on the sides and put tinted plexi, and make a new front, with tinted plexi in it to. (hehe)
    Things I absolutely will do is making room for a 120mm fan in the front, and silence it.. and as I said, I'll start after xmas! :dremel:
  2. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    That's gonna have to be a pretty huuuuuge window to get rid of all that design.
    Other ideas.... I guess that standard really, CCFLs, LEDs, spray/powder coat, VFD, stealthing drives etc....
  3. Jokkocze
    16 Dec 2004
    hehe ^^
    that's not what I meant..
    removing those stupid things! *points*
    dun like cases that dun got plain sides, so those got to go :p
  4. zx2assassin
    zx2assassin What's a Dremel?
    22 Sep 2004
    well you could do as mentioned earlier and cut a window in it, im thinking if yu wanna get rid of the stuff that you probably could use some bondo on it...but I have never used it before so I'm not sure
  5. Jokkocze
    16 Dec 2004
    hmm.. what's bondo? never heard 'bout it before
  6. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    bondo is filler for well holes and stuff. It is mostly used in car's(at least thats all i ever really here it used). Bondo would fill all those holes up but it can get pretty messy to do it so the easiest way to fix your delima would be cut that out and put either plexi glass or like a sheet of metal to cover it up.
  7. Burke
    Burke What's a Dremel?
    21 Dec 2004
    Use Bondo I used it for my fisrt timeand it was easy peasy...
    Have something flat thall lay against the inside of the panel, flush to the panel,...mix your bondo,...spread it on like Drywall putty,...letter dry,...sand.
    See what I did.
    Same panel....One area bondoed up....(yeah i know one pic is upside down :duh: )
  8. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    you should stealth all the cd rom drives.
    there is a tutorial on it somewhere ill look later
    you should also do a window in some kind of shape. if i was you i would have the plexi etched with a pic of something on it.
    i wanna see how this comes out good luck
    subscribed
  9. Jokkocze
    16 Dec 2004
    yay! someone suscribed! well, I still wont start til after xmas.. (my dremel's broken, and I know I'll get a new one :p)
  10. CaseyBlackburn
    27 Jul 2004
    No prob subscribing
    we can all wait till christmas for you to continue. doesn't really matter only 2 days away.
  11. Jokkocze
    16 Dec 2004
    hehe.. in sweden, we get our stuff in the evening of the 24'th.. guess it's because santa cant be everywhere in one night :hehe:
  12. Jokkocze
    16 Dec 2004
    Got 2 dremel copies now, so I can start modding! But I need some plexi... or well, alot of plexi
  13. Jokkocze
    16 Dec 2004
    ok, made a fast drawing of my ideas in sketchup:
    I'm gonna make a new little front, without any ugly cd's or anything. And since I'm to lazy for making any big holes on the sides of the case, I'll just place heavily tinted plexi there ^^
    All tints will be red, and the case'll be black :hip:
    (aaw :waah: no replies :( )
  14. SuperFreak
    SuperFreak What's a Dremel?
    16 May 2004
    Ok, its after christmas now. Where's the modding?
    And go for the sketch, it looks pretty cool! :thumb:
    Good luck!
  15. CaseyBlackburn
    27 Jul 2004
    Sorry for the no replies from me ive been with family
    back on topic: the sketch looks good go for it.
  16. Jokkocze
    16 Dec 2004
    ok, nice!
    havent started yet since I've been hanging with my mates a bit to much.. and I've got no camera atm (exept webcam, and nobody likes that..)
    Although, when I go to malmö (town not far from here, where u can buy cool stuff) to return one of them multitools, I'll pick up some modding stuff, and then I'll start at once. (wedensday or thursday..)
    edit: Stripped the case down, and I've got to say, it aint heavy! But it aint very stabile.. I'll see what I can do to fix that..
    (Btw, this is my first mod evah*.. so I hope it turns out good.. or I'll loose all my selfrespect :wallbash: )
    *(comicbookguy style)
  17. Jokkocze
    16 Dec 2004
    ok, question:
    Can the buttons from a mouse be used as power on and reset buttons? (How much power can they handle? and how much power goes through the button?)
    would sure be cool to have them :)
    (dead again :waah: )
  18. Jokkocze
    16 Dec 2004
    Ok, seems very dead, but I'll keep on posting anyway...
    Made a ugly sketchup of the front in photoshop.. it'll look something like this:
    as I said, it's a very ugly sketch.. hopefully, the real thing'll be better.
  19. WaZzUp115
    WaZzUp115 What's a Dremel?
    12 Feb 2004
    Bondo is "spackel" in swedish, like plastic padding..
  20. Jokkocze
    16 Dec 2004
    yeah.. I know.. got a pm bout that for like 2 weeks ago :D (efter att jag klurat lite och listat ut de själv..)
