Modding Finished m0dding my baby....
Discussion in 'Modding' started by Jamie, 14 Aug 2001.
  1. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    After spending a few bob she is finally finished......
    3 panaflo 80mm blowholes, one in the front, one in the rear and one at the bottom. There is also a 60mm blowhole behind the cpu.
  2. BLZ BOB
    BLZ BOB What's a Dremel?
    14 Aug 2001
    Nice 'nuff said
  3. Phil
    Phil What's a Dremel?
    19 Jul 2001
    Just an idea - but I'm thinking how about you make that 60mm blowhole by the cpu push air the other way - at least try it and see if it helps.
    I've got this idea going around in my head about the way the air moves around the Heatsink...and it's telling me that blowing some cold air at it rather than sucking the air away from the heatsink's fan might yield better results....
    That assumes you're heatsink fan's a blower and not a sucker of course....
    try it and see ?
  4. Jamie
    12 Mar 2001
    good idea .... ill have to try that one .... ill post the results when I do it
    *edit* Not much of an improvement .... i stuck my delta at 7 volts on the heatsink now ... slightly better results
