Disaster Fire in the Hall
Discussion in 'Modding' started by Azh_fx, 5 Oct 2003.
  1. Azh_fx
    Azh_fx sup dawg?
    11 Jul 2003
    oh boy, i decided to overclock my pc spme more, heard the dreaded beeps so had to take my case panel out to reset the cmos bios jumper, done all that placed the cover back on
    (i was lucky i didnt screw the panel back on)
    put the pc on, all of a sudden black smoke started to pour out of the fan outlet from the window panel fan
    at this time the led fan had turned off. i go to press the power botton (damn thing was on a 4 second power off mode).
    waiting for the four seconds to count down i noticed a flame had started up in my case, (nice and bright and orange and ...did i mention bright?)
    one hand was on the power button and the other was trying to remove the panel off. (note on a normal day i would just switch the psu off)
    Ok then, the power had gone off and i managed to take the case off and i saw the "fire".
    i blew and blew and the flame started to get bigger, i manged to puff the fire out after a few attempts.
    the remains (rip)
    tried the pc after running a big fan to get rid of the smoke and thankfully everything is working fine :p
    that was a close 1
    looks like i shorted the wire from the led fan onto the case or something similar!
    ...but most of all the pc lives on :)
  2. relix
    relix Minimodder
    14 Nov 2001
    Fire!!!
    Any damage to the inside of the case maybe?
    Good to know everything is fine, especially that sexeh CNPS7000 :brrr:
  3. Azh_fx
    Azh_fx sup dawg?
    11 Jul 2003
    its all fine cept the window has some burn marks :p
    and some red wire embeded in the plastic
  4. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Could call it a 'design feature' :hehe:
  5. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    It was premod anyway :p :D
  6. corrosive_nf
    corrosive_nf What's a Dremel?
    30 Aug 2003
    its fire in the hole not hall
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    same thing happened to me wen i took all the guts out of my comp i failed to notice that i had pulled the actual wires out of the plastic floppt power conector
    wen i put it all back together
    crackle crackle flames :eeek:
    not much damage tho jus some melted plastic
    scary at the time tho :duh:
  8. Megavolt
    Megavolt What's a Dremel?
    4 Apr 2003
    I am glad your experience was only exciting and not expensive :eeek:
  9. Shogun
    Shogun Banned
    18 Jul 2002
    that happened to me but with two led fans when i tried to make my own baybus.It does produce quite a bit of smoke doesnt it :lol:
  10. (Ck)Vegeta
    (Ck)Vegeta What's a Dremel?
    23 Jan 2003
    Ouch
    Yeah Right Be Happy it was only a Led Fan Thank god it wasnt anything worse :jawdrop:
  11. Azh_fx
    Azh_fx sup dawg?
    11 Jul 2003
    yrah then the bonfire :p
    which when you blows
    goes bigger and bigger
  12. Zoomer
    Zoomer What's a Dremel?
    30 Jan 2003
    I'm sure i remember being told a few times that bundled cables get HOT.
    A few years ago now a similer prob when a cable warmed up and started to produce smoke. but i stopped it before any fire was about.
  13. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    so what caused your fire exactly?
  14. keir
    keir S p i t F i r e
    5 Oct 2003
    first off for some reason it wouldnt let me pm you. so sorry about this.
    those beeps have happened to me before an I had to take it to a shop to be fixed. and I dont fancy paying £10 for someone to take off a jumper and them put it back on, if thats all you have to do.
    please can you explain what you have to do to boot the system up if it doesnt stop the beeps :worried:
    thx keir.
  15. Jaguar_Infinity
    Jaguar_Infinity Just some guy
    8 Oct 2003
    flame grilled extra crispy with fries on the side please :D
  16. white modder
    white modder What's a Dremel?
    19 Sep 2003
    NEVER blow on flames (but you already knew that :p )
  17. Darv
    Darv Bling!!
    12 Aug 2002
    Re: Re: Fire in the Hall
    You cant pm on these boards - reason's in the rules
    About the beeping - its usually because its overheating or you've clocked it too high.
    Simple solution is to reset the bios. Look in the manaul for the exact details but its pretty much the same on all boards.
    Unplug the computer from the mains. Then take out the battery on the motherboard. Now you need to move the CMOS jumper from one position to another and then back again. Replace the battery and turn the computer back on. The bios should be at default values now.
  18. Krikkit
    21 Jan 2003
    I managed to set something on fire a while ago - was my own stupid fault though. I soldered a 330ohm pot in series with an 80mm Delta fan. Needless to say, after watching the ceramic resistor casing crack it set on fire :D.
    Lucky escape for you there mate, that could've been nasty...
  19. phOny Boy
    phOny Boy What's a Dremel?
    26 Nov 2003
    Perhaps his pc was in the hall? ;)
  20. Kermet
    Kermet [custom title]
    18 Feb 2003
    AHHHHH! FIRE! :eeek:
    I've never had anything catch fire, or even just melt dramatically, but reading posts like these makes me think twice since I often leave my computer on and unattended for days...
