Windows Firebird Question
Discussion in 'Software' started by quack, 25 Nov 2003.
  1. quack
    quack Minimodder
    6 Mar 2002
    Does anyone know how to make Firebird download more than 2 files at once? I know how to do it for IE, with a simple registry tweak, but how for Mr Moz?
  2. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    I know I've had at least 3 downloads going at once in Firebird. I didn't see a setting to change it though.
  3. quack
    quack Minimodder
    6 Mar 2002
    From the same server? I think the default for most browsers is to only download 2 files from the same server at a time. I'd rather it was 10 or so.
  4. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I had never noticed anything about that until I read this. Hmm....
    There may be something that you can set in a config file. See here. But I didn't see anything specifically spelled out. I'll keep looking though. :geek:
  5. Carbon
    Carbon Banned
    8 Jan 2003
    firebird??
  6. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    Mozilla Firebird :)
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Floats like a butterfly, stings like a bee. linky :thumb:
  8. ajack
    ajack rox
    17 Apr 2003
    Sorry for the thread revival but I was wondering how to do this today and a search on here/google didnt reveal much.
    To get more than 2 simultaneous downloads in firefox type "about:config" (without the quotes) into the browser window, then about 60 lines down there is a field called Broswer.Download.Manager.Retention, double click this and change the value from 2 to however many simultaneous downloads you want.
    [EDIT] OK random but when I posted this message it added a "_" after the word about. You need to type the about config thing without the underscore :)
    Ive had about 15 downloads going at once (testing to see if it worked) so there may be some server side limitations but I havent come across any yet
  9. Trickle
    Trickle What's a Dremel?
    14 Dec 2003
    I didnt know that about firebird - useful info.
    Sometimes the 2 files per site can be a limitation imposed by the site itself I believe?
