News Firefox 3.5 suffers critical JS flaw
Discussion in 'Article Discussion' started by CardJoe, 16 Jul 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. lp1988
    lp1988 Minimodder
    24 Jun 2008
    Running 3,5 but not using that manny diffrent sites so as long there is a fix within a reasonable timespan, I won't be worried.
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    I'm still on 3.0.11 because not all of my addons work with 3.5. Now I feel even better about it :clap:
  4. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    LOL I just upgraded yesterday. How does the "flaw" affect Vista with its UAC?
    Ctrl + Shift + Pr0n for the win
  5. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Simple work around using about:config, but it look likes tracemonkey is still being a naughty sod. I wonder if you have to be running an admin level account, for the remote software to install?
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yeah vista uac would catch this I would think.. thanks for the heads up though- running the 3.5 guinea pig
  7. Turbotab
    4 Feb 2009
    There are malware packages that attempt to gain admin level access, by trying to crack the admin account's password, which in many cases may be very weak.
  8. Otto69
    Otto69 What's a Dremel?
    6 Oct 2007
    I'm still using 2.x on some of my computers because 3.x can be a performance and reliability pig.
    Also I just LOVE how every install of Firefox is a crapshoot as to whether it will delete some or all of my myriad bookmarks.
  9. thehippoz
    19 Dec 2008
    yep.. actually if your like alot of people on pre-builts they put the password unencrypted in the registry- and they disable the uac anyways
    the overflow should set off the uac though- I'm just guessing and not willing to try it- maybe after this weeks backup and they have no patch lol
  10. pendragon
    pendragon I pickle they
    14 May 2004
    glad I use both IE and Firefox ..always have the freedom to use one or the other!
  11. airchie
    airchie What's a Dremel?
    22 Mar 2005
    It runs at whatever level you're logged in as so if you're running a restricted user account then you should recieve minimal damage.
    xmarks FTW. ;)
    Or alternatively, you have double the number if infection vectors to worry about... ;)
    FF + Noscript + xmarks = tehwin IMO :D
  12. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    I use NoScript anyway. It's a genius little addon.
  13. sear
    sear Guest
    NoScript and Adblock, coupled with Spybot's immunisation and SpywareBlaster's magic stuff, basically make Firefox an impenetrable fortress. The only way my computer's getting infected is if I let it get infected.
  14. impar
    impar Minimodder
    24 Nov 2006
  15. dicobalt
    dicobalt What's a Dremel?
    21 Mar 2009
  16. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Your using UAC? rofl
    It probably has no idea whats going on inside firefox, just that it allowed FF to run...
  17. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    3.5.1 is now available through the auto update.
  18. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    This is hilarious.
    ALL HAIL IE8!!!!!!!!!!!!!!
  19. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Before people start touting x is more secure the same vulnerability has been proven to crash safari, kill the process in ie8 and just makes chrome lockup.
  20. crazyceo
    24 Apr 2009
    Yeah but you have to have a little fun every now and then.
Tags: Add Tags
