News Firefox 3 Beta 1 available
Discussion in 'Article Discussion' started by CardJoe, 23 Nov 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    It's not bad, it is slightly faster to load pages too however there is a serious issue where its breaking stuff that is inside of a table, where FF2 would just format it correctly and wrap to the next line FF3B1 doesnt seem to, it actually puts a scroll bar in which is very irritating.
    As with places, I cant honestly see myself using it much as I rarely bookmark anyway, I tend to remember URL's.
  3. The Chugnut
    The Chugnut What's a Dremel?
    8 Oct 2007
    I've spent the last 15 minutes trying to make it crash, but have failed. I'm very impressed.
    I'll have to live without some addons until they're updated, but it's all good.
    Faster Firefox without any nasty hacks. Top stuff!
    Edit: I see what you mean BioSniper, that's not good news.
  4. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Before I go installing this, it doesn't overwrite your current Firefox version does it? I don't want to go loosing all my addons. I need 'em for work.
  5. The Chugnut
    8 Oct 2007
    Yeah, sadly it does. The Web Developer bar, I would imagine, will be updated pretty sharpish. *crosses fingers*
  6. BioSniper
    5 Feb 2002
    It shouldn't will, I have both installed, you just have to run one or the other, you cannot run both exe's at the same time.
  7. Hiren
    Hiren mind control Moderator
    15 May 2002
    It didn't for me, I have both installed on my system right now.
    Beta 1 was ok nothing too special. Pages were faster loading.
  8. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    Page loads are significantly faster, the layout engine still needs a few tweaks but over all a very good improvement.
  9. quack
    quack Minimodder
    6 Mar 2002
    The toolbar that appears when it asks you if you want to save your password or not is pretty excellent. I hate having to answer the question before I find out if I actually got the password right or not.
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I installed the alphas (Gran Paradiso) no problem, just do a custom install and tell it a different folder. Save your profile just-in-case. I found the alphas stable enough, but a few too many bugs and rendering faults for regular use.
  11. Bionic-Blob
    Bionic-Blob What's a Dremel?
    2 Aug 2007
    isn't this beta 2? i recall beta 1 was earlier this year sometime
  12. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    *puts on Opera hat*
    Or check out the 9.5 beta released weeks ago which contains pretty much all the features implemented better and a faster renderer and better memory usage.
  13. GoodBytes
    20 Jan 2007
    I find it to start faster then Firefox 2.0
  14. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I tried it... but the vast majority of the extensions/themes I use don't work with it - so I'll be sticking with version 2.x until such times as they are updated/do work :sigh:
  15. airchie
    airchie What's a Dremel?
    22 Mar 2005
    But has it changed the alt+S shortcut for history?
    I used to use that to save quick posts on these forums and others and now I can't.
    Reeeeally irritating. :(
  16. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    THEY FIXED THE LEAK? Holy ****ing hallelujah. Took long enough.
  17. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    i don't like the download window.
    and omg, as i type this, its spotting mistakes! winner.
  18. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    you can turn this off with one of the options in about:config
    try googling it
    i didnt upgrade to FF2 until i worked out how to fix this issue :p
  19. Jipa
    5 Feb 2004
    I don't really notice any difference on the speed.. And I'm pretty sure I just installed this over the FF2 I had. Oh well it happens.
  20. iwog
    iwog Linux cursed
    14 Jun 2007
    Ha, I've just installed it and sent of two bug reports already. One was cos I was messing about with the default programmes thing in the options and the other was i tried to do my "new tab gesture" forgetting all-in-one gestures wasn't installed, it didn't like either of them.
    My thoughts on the new FF are:
    Yea! less memory usage
    Ooo pretty new star
    Boo, my add ons dont work
    Overall, I wont be a tester, no matter how frequently i can generate bug reports I'm not using the new FF until 80% of my add-ons work. I supposed I could get my friend to teach me how to edit the .xpi's again and change all the version numbers, but it just seems like too much hassle.
    @Jipa: you wont have written over the old FF, it installed it into a separate directory so just use your old FF link or hotkey and viola FF2
Tags: Add Tags
