News Firefox 4 Beta 4 includes Direct2D
Discussion in 'Article Discussion' started by CardJoe, 23 Aug 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Quote: "Thankfully, enabling the acceleration is pretty straightforward for the more advanced users willing to give the bleeding edge a try: "To turn on Direct2D: Go in to about:config and set mozilla.widget.render-mode to 6, and gfx.font_rendering.directwrite.enabled to true."
    That is hardly straightforward, it might not be difficult, but try explaining that to an older generation compared to going to something like Tools - Options - Tick box for 2D acceleration.
    TBH, it's about time Mozilla and others made these advanced features more readily available for the more common things that day to day users might benefit from.
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    But then again why would the "older generation" be using beta software? It's obvious that these options will be in the "appearance" preferences in the menu, probably, in future, stable releases.
  4. mclean007
    mclean007 Officious Bystander
    22 May 2003
    @tad2008 - that's a bit unfair - it's a beta feature that by the developers' own admission isn't yet ready for a full rollout. Most day to day users don't need to be messing about with features that aren't fully developed yet - they're better off with a more stable, if fractionally slower, browsing experience.
    I'd expect that in the final release of Firefox 4 this will be enabled by default, and nobody will ever really need to turn it off.
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    TBH, you absolutely do not get this at all. You need to actually download the Minefield nightlies in order to even get this option, which are very unlikely for the older generation to EVEN know about it, much less download and install.
    Fail.
  6. Gareth Halfacree
    4 Dec 2007
    Which is exactly what the option *will* be on final release. Remember, this is a *beta* - i.e. an unfinished product for testing purposes.
    Plus, if you read the sentence again, I said it was "pretty straightforward for the more advanced users." Somehow, I doubt that members of your apparently senile "older generation" read bit-tech and install betas.
    Just sayin'.
  7. phuzz
    phuzz This is a title
    28 May 2004
    Not bothering with the FF beta until my addons are all updated to work with it :p
  8. a6361563
    a6361563 What's a Dremel?
    23 Aug 2010
    Almost every add-on is working fine with the Beta. Just install "Add-on Compatibility Reporter" add-on.
  9. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I've never really liked Firefox tbh, always been afraid it will eat my babies.
    Let me know when Chrome or Opera adds this feature.
  10. Saivert
    Saivert Minimodder
    26 Mar 2005
    Firefox 4 beta 4 is not released yet. bit-tech needs to stop snooping on the Mozilla FTP server. just because something is put up there does not mean it is officially released.
    this is as said a minefield nightly and I've been testing Direct2D enabled Firefox for quite some time now.
    Direct2D "code" is already in Beta 3
  11. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I'll wait for the official release, I just need stuff to work i'll leave beta testing to others.
  12. Kenny79
    Kenny79 I own a Dremel!
    18 Oct 2009
    Never could figure out why Firefox was so popular, I tried it a few times but couldn’t grow to like it, then Chrome came out and I’ve never looked back its just fast and easy. Different strokes for different folks I guess.
  13. sear
    sear What's a Dremel?
    2 Aug 2010
    Actually, as far as I remember Direct2D was already in as far back as when it was called 3.7. Way to make a story out of non-news, guys!
  14. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
    Also it probably won't be popular with the mainstream (unless Mozilla somehow changes it between now and release) as it also requires Vista/7, WDDM drivers and its not recommended to use Intel graphics chips, which will be what many people have. Can't say I've really noticed any difference in memory, its still using nearly 400MB (albeit with several tabs open)
  15. Sexton
    Sexton Minimodder
    2 Jun 2010
    Where can I download beta 4? Have looked everywhere, but most recent I can find is version 3.
  16. Vigilante
    Vigilante What's a Dremel?
    30 May 2008
    I dunno what's going on here, but this method of enabling D2D has been part of the minefield builds for nearly two months - ever since it was renamed from 3.6pre (though code-wise more advanced than 3.6), to 4.0.
    This feature is enabled by default in the firefox 4 prebeta 5 builds (available here, so beta 5 should have this enabled by default too. Be patient if you don't like fiddling around with about:config.
  17. pbryanw
    pbryanw Minimodder
    22 Jul 2009
  18. Sexton
    Sexton Minimodder
    2 Jun 2010
    Ah OK, thanks :)
  19. Evenge
    Evenge Minimodder
    16 Sep 2006
    Well I use Minefield as my default browser, and I like it. But some times it is bit annoying that beta dev team enable some features which clearly aren't working.
    I'm not sure is the problem with Direct2D Firefox beta based error, or aren't web pages just simply coded whit D2D in mind, since at least youtube has some issues playing vids properly when D2D is enabled (might have something to do with Flash...)
  20. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    firefox and Chrome seem to be bit heavy on ram use, i must have about 60-70 tabs open in opera and its using like 1gb of ram (i got more tabs open then norm as ram use is norm 400-600MB with 40tabs) 4 tabs are open in chrome right now and they are using 300-400 each Flash seems have have an negative impact on firefox and chrome seems to have an mem leak thats not been fixed yet
Tags: Add Tags
