News Firefox 4 downloaded 24 million times in three days
Discussion in 'Article Discussion' started by arcticstoat, 25 Mar 2011.
  1. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I love it :)
    The wasted screen real estate was really beginning to get to me, but with the new interface I feel like I've just upgraded to a bigger monitor. I also like the tab groups and pinned tabs. My only gripe is that I had two windows open when I set up my groups and pins and I closed them in the wrong order, thus losing all the changes :(.
    Now I'm too busy with my iPad to set them up again.
  2. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    Like the overall UI now, old FF versions for me looked a bit, well, childish,lol, its only me though, we have diff tastes. id be honest though, im still on chrome even though I downloaded FF. IE/Chrome most of the times.
  3. ObeyTheCreed
    ObeyTheCreed What's a Dremel?
    28 Jan 2011
    FF is freaking epic, smoother, has more customizable options, and it just looks better than explorer, i'm using FF4 right now :D
  4. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    FF4 is good, and still my first choice of browser.
    However IE has closed the gap to nothing. In my opinion they are both as fast as eachother. IE infact starts up slightly faster on windows7 64bit and it seems it loads pages a little more smoothly. I use IE at work and FF at home because I am use to my FF addons. If it wasnt for the addons then I would probably use IE9
  5. Pooeypants
    Pooeypants What's a Dremel?
    12 Jun 2010
    I moved from Firefox to Chrome about a year ago due to inconsistent but regular memory leaks from flash items etc. Just trying out 4.0 now and it "feels" nice but I'm so used to Chrome's simplicity. Hmm.
  6. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    just going to be adding one more to the download count (on version 3 with IE totally removed from my windows 7 enterprise install)..
  7. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    I like the new FF4, the layout, the everything. Just feels right!
    Chrome for me just feels and looks wrong and from working in suport haven't come across a browser which cause more headaches then Chrome.
    I've very impressed with what M$ has done with IE9, it definately is a competitor and my 2nd choice to FF4 but just the feel, the look, and now the app tabs and tab groups I'm addicted to I can't see myself using any other browser and all this is PRE add-ins which I've not been playing with but will definately improve by browsing experience and fix youtube.
  8. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    NO, it's a fact.
  9. Xir
    Xir Modder
    26 Apr 2006
    I turned off the "awesome" bar behaviour and don't really need the searchbox either.
    Very happy it's easily customised now though.
  10. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Chrome updates itself in the background. By default you cant turn it off and it doesnt tell you there is an update being installed. It might do if a update changes alot of things in the UI but most do not, certainly none since the silent update method has been used.
    You have to tinker with the registry to stop it updating, not sure if there is an extension that does it though.
    http://blogs.sitepoint.com/how-to-disable-google-chrome-updates/
  11. 3lusive
    3lusive Minimodder
    5 Feb 2011
    Just downloaded and tried FF4, seems decent so far - the layout and responsiveness is good. But its still not as quick or as streamlined as Chrome IMO, so I wont be turning back anytime soon
  12. shigllgetcha
    shigllgetcha Come at me bro
    3 Mar 2008
    Its an opinion at best
  13. Xir
    Xir Modder
    26 Apr 2006
    Thanks! :thumb:
    I'd like to "initiate" an Update, chrome is installed on a computer I rarely use these days, and is probably quite a few updates behind.
    Is that possible?
  14. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    It wasn't me! Seriously.
    Any browser which want to look like Chrome clone is D.E.A.D. for me, forever.
    Using Maxthon for stubborn "designed for IE/FF" sites, otherwise...
    Opera Cheesecake! Mauling competition since version 3.0.
  15. [-Stash-]
    [-Stash-] What's a Dremel?
    23 Nov 2005
    Sure, just fire up chrome, wait a minute or two (depending on your net connection speed) and restart it :D
  16. Snips
    14 Sep 2010
    NO, it's a fact that don't want or need FF.
  17. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    Seamless switch from FF3.6 to FF4.x on Linux-Mint 10. No chance of using IE 9.0 here!!
    I prefer the tabs the tabs laid on top. Also the speed is much better in FF4.x (I tried the early Windows betas and they were all over the place)!! What with Firefox sync and all my other add-ons I don't need another browser really (now the speed issue has been sorted out). The Mozilla Foundation claimed to have completely rewritten the code-base for this release (in a podcast I was listening to recently) - appears to be the case as well!
  18. Xir
    Xir Modder
    26 Apr 2006
    Nothing happends.
    *sigh* was a "look for updates now" button really that much work? :sigh:
  19. Edwards
    Edwards Minimodder
    8 Oct 2010
    Click the settings button, and then 'About Google Chrome'. This forces an update check.
  20. Xir
    Xir Modder
    26 Apr 2006
    Thanks, I'll try
Tags: Add Tags
