Linux Firefox a bloated pig?
Discussion in 'Software' started by Kipman725, 28 Feb 2007.
  1. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    on all my pcs firefox tends to eat upto 128mb of ram with only about 15tabs open and it can also slow my pc to a crawl and use about 90% cpu randomly. Anyone think that it's become too bloated?
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    oh, no, your 4ghxz machine with 2gbs of ram has a process running using 120MB of memory with _only_ 15 tabs showing?
    1 - it's open source - it's not going to be massively optimised
    2 - 15 tabs? that#s not a trivial amount. plugins, flash, images, they all add up.
    3 - really, honestly who gives a toss.
  3. RTT
    RTT #parp
    12 Mar 2001
    ^ see above.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Can I smack you? OSS is more optimised then CSS in my experience... OSS dev's are about the only developers that actually optimise code
    This is true however...
  5. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    I'm with Fod on this one. Just for fun, next time that's happening open the same series of tabs in IE (get the history trails the same if possible) and see if it does much better. If so, switch quietly back to IE - to the best of my knowledge it's no longer a horrible security risk since version 7 came out. Personally, I use Firefox because I like it, not because it's faster. If you don't want to use the features of Firefox (extensions, mostly) then don't use Firefox.
  6. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    IE 7 sucks, kills my computer performance.
  7. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    you gotta be joking putting ie on linux?
  8. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    What version are you using?
    im still on 1.5
    But ive heard the 2.0 has become far to bloated due to lack of things to fix
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Actually, I had to. I use a D-Link router which has a linux OS. Unfortunately, the f***tards at D-Link wrote the OS in such a manner that I can only properly secure the wifi in IE6 run under WINE :wallbash:
  10. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    for some silly reason that part struck me as funny
  11. Kipman725
    1 Nov 2004
    Im running version 2.0.0.2
    and no web browser should use as much ram as firefox does, I used to be able to browse the web with 4mb of ram total.
  12. AJB2K3
    12 Dec 2005
    Have a look at about:config
    There should be an option to adjust the memory usage.
    Whats the FF foundation forum sudjest?
    It was for me writing it.
  13. curtisjade1
    curtisjade1 What's a Dremel?
    28 Feb 2007
    [​IMG] [​IMG]
    Nuff Said
  14. Glider
    Glider /dev/null
    2 Aug 2005
    You are correct, if you just browse text only pages... Now, if you open lots of big photo sites etc, higher memory usage is inevitable...
  15. GoodBytes
    20 Jan 2007
    could be a firefox extension that has a bug...
  16. Woodstock
    10 Sep 2006
    slightly different then day to day usage, i believe a read somewhere that theres a firefox extension to "fool" things into thinking its ie
  17. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Really? May I ask what your experience of auditing OSS and CSS is? I'm a CSS dev and take optimisation seriously so I hope that your experience has either been bad and/or limited.
    (if that sounds rude then sry, it isn't meant to be)
  18. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I only know of IETab but it only works under windows since it just opens an instance of IE in a FF tab
  19. Glider
    Glider /dev/null
    2 Aug 2005
    I'm closely involved in some OSS projects, and if the CSS developers would take optimalisation as serious as we have to (the maintainer is quite strict about it) a lot of programs would run a lot smoother. Also, at my high school there are some MSDNAA (IIRC) developers that teach me, and they have nowhere near as optimised code as the OSS projects I'm involved in.
  20. Fod
    26 Aug 2004
    nah student code is never optimised - it's designed to be easy for the student to follow and understand. (don't get me started on MSDNAA)
    commercial code? you spend aaaall your bloody time in profilers.
