Windows Firefox driving me up the wall!
Discussion in 'Software' started by Bogomip, 2 Nov 2006.
  1. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    It wont stop bouncing around! It just "shakes" a little bit and its driving me up the wall! Anybody know how to fix this or if its a reported bug in FF 2.0 ? Can't find anything immediatele obvious on the FF website!
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    No problems here.
    Sure it's only Firefox?
  3. DougEdey
    5 Jul 2005
    Is it on any particular website?
  4. widmod
    widmod Minimodder
    9 Oct 2006
    newbies advice
    Do you use a CRT monitor?
    mine is doing such things too :D because of
    the (power) cable mess around here...
    paul
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I once had this effect on a much earlier Firefox, see here for some causes (and I spit on your Search skills :p).
    If none of the fixes work, check your Options/Advanced, try changing the scroll checkbox setting. I think it's advised to have Smooth Scroll off, Autoscroll on.
  6. Bogomip
    15 Jun 2002
    Awesome cpemma, thanks :) Yes, my search skills were weak :(
