News Firefox fix released for JavaScript flaw
Discussion in 'Article Discussion' started by Guest-16, 18 Apr 2008.
  1. Guest-16
    Guest-16 Guest
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Whohoo! :clap:
    I have had some problems with this lately. Some of the commercial banners on some of the newspapers I read daily made FF crash. Hopefully this should fix it :)
  3. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    That explains quite a lot. When using stumble upon, pages would sometimes cause a crash if they contained javascript. Usually they'd load fine on a restart.
  4. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Hopefully this will get fixed on FF3 Beta as well, I get quite a few crashes on the Uni website that uses java.
  5. Anakha
    Anakha Minimodder
    6 Sep 2002
    The FF3 Beta uses a totally new JS interpreter and GC.
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    its typical when Microsoft enforced an IE update, the world falls over it. And we web-developers still have to write compatible code for absolute old browser versions like IE5.5 and IE6.x. But if firefox forces a upgrade all is good and shiny...
  7. Gareth Halfacree
    4 Dec 2007
    But it only 'forces' an upgrade if you've selected "Automatically download and install the update" in Preferences -> Advanced -> Updates. If you've selected "Ask me what I want to do" or just un-ticked "Check for updates to Firefox" then it doesn't.
    Plus, I'm confused by your reference to web developers writing "compatible code" - this update is purely to fix a bug in the JavaScript garbage collection process. There's no change to the rendering engine whatsoever, so there's no need to change any coding to accommodate this point release.
  8. DougEdey
    5 Jul 2005
    FF3B* doesn't work with HSBC internet banking.
  9. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Do we know if its FF3B* that doesn't work with certain Java websites or are the websites poorly coded?
  10. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    FF3 Beta 5 works fine with HSBC online banking. It keeps crashing on burning on me though when browsing random forums.
  11. kno3
    kno3 What's a Dremel?
    29 Mar 2008
    Works fine for me. What is happening with you?
  12. DougEdey
    5 Jul 2005
    Sorry for the delayed response, it started to work again.
Tags: Add Tags
