Windows firefox: open file
Discussion in 'Software' started by Nedsbeds, 30 Mar 2005.
  1. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    Is there some way to set firefox so it behaves like ie when clicking files that you want opening. The main example is streaming video. if you click open file in firefox it downloads the file then passes it to media player, (ie would pass it straight away and media player would dl it)
    Just want to know how cause its annoying having to copy the url into MP.
    Cheers
    Ned
  2. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    if you 'open in default application' it should do that on it's own. Normally you need a plugin to make it work in browser but playing in independant WMP, you just need to open it.
  3. Nedsbeds
    16 May 2002
    it doesnt though. It downloads the file in firefox first and then sends it to the application.
    Not great for streaming stuff!!
  4. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I think the Firefox forums have what you're looking for:
    That is from here.
  5. Nedsbeds
    16 May 2002
    Cheers boyo. Just the ticket
    Ned
  6. Deviate
    3 Jun 2002
    w00t! I can be helpful after all. :D :clap:
