Windows Firefox RC2 extensions
Discussion in 'Software' started by cpemma, 9 Oct 2006.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Found 4 of my must-haves
    Chromedit +
    Titlebar Tweaks
    Statusbar Clock
    Spellbound 2
    plus a few more here already upgraded to FF2.0 by their author; less risk than me bumping the maxversion... ;)
  2. DougEdey
    5 Jul 2005
    I found for about 3 days I was regularly getting updates to my extensions.
    But for some reason when I leave FF RC2 I get the mozilla bug agent coming up.
    Bloody odd.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I do the custom install and always uncheck that, just in case it's bloaty. :worried: And one thing less to go wrong. ;)
    Finally got the default spellchecker working, I think the previous Spellbound Developer one may have been messing things up. Color/colour says I have a Brit dictionary. :rock:
    Tab Mix Plus (Dev Build) seems to work OK, still a big improvement on the built-in "improvements". :sigh:
    edit: There is a teething problem with TMP(DB), the TMP 'Session Restore' acts in addition to the new FF2 one, so close 10 tabs and 20 re-open next time. :duh: Fix is to use one or the other, but not both. Turn FF one off by creating a new boolean in about:config, 'browser.sessionstore.enabled' making it 'False'. Or just turn the TMP one off through the TMP Options.
  4. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
  5. DougEdey
    5 Jul 2005
    I keep it on because its beta software, the more info they can get the better it'll be for us in the long run.
    Tab Mix Plus sounds like its being incorporated into FF2, so it may become just bloat ;)
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
