Other Firefox Speedup tip
Discussion in 'Software' started by deathtaker27, 1 Sep 2010.
  1. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    If you have broadband (as most of us do), you can use something called pipe-lining to speed up firefox. This allows multiple objects to be downloaded at once. below is everything, do at your own risk :)
    Here's what you need to do:
    * Type "about:config" into the address bar and hit return (you probably want to do this in a seperate tab so you can check back here).
    * Type "network.http" in the filter field, and change the following settings (double-click on them to change them):
    * Set "network.http.pipelining" to "true"
    * Set "network.http.proxy.pipelining' to "true"
    * Set "network.http.pipelining.maxrequests" to a number like 30. This will allow it to make 30 requests at once.
    Right click a blank space in the window and Create a new integer value called "nglayout.initialpaint.delay" and set it to "0".
    Right Click a blank space in the window and create a new Boolean Then enter "content.interrupt.parsing" in the New boolean value pop-up window and click OK, then set this to "true" when prompted.
    Restart your browser, it should be noticeably faster...
    Enjoy faster forums guys ;)
    matt..., andrewbarke, Booga and 15 others like this.
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I heard about these settings before. Here's hoping they make it a proper system in Firefox 4.
  3. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    we can hope, but before that we can just do it ourselves.
  4. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    lol now it's too fast :p
    Thanks.
  5. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    try nglayout.initialpaint.delay == 5
    it's not so blunt drawing the screen as it loads :D
  6. Nexxo
    23 Oct 2001
    Wow. Faaaaast!!! :)
  7. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    Wow, thanks. Have some rep :)
  8. Pookeyhead
    30 Jan 2004
    That made no difference here.
    [edit]
    No... wait... Hmm.. maybe.
    [edit of edit]
    Indeed it is. Rep given
  9. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Nice one thanks :)
  10. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    thats awesome rep coming your way
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    wooooooooooooah
  12. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    sorry thats a side effect ;)
  13. GoodBytes
    20 Jan 2007
    Niiiiiiice!
    +rep
  14. murraynt
    murraynt Modder
    6 Jun 2009
    It there any point in doing this for fire fox 4 BETA?
  15. GoodBytes
    20 Jan 2007
    Firefox 4 is already fast... I did it, and I saw a a bit of a speed increase (visually), so it's welcome change, and I like it.
  16. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Worked for me, rep given. :thumb:
  17. murraynt
    murraynt Modder
    6 Jun 2009
    Ill have ago of it so.
    Thanks.
  18. murraynt
    murraynt Modder
    6 Jun 2009
    It worked:D
    Ill follow the example and give some rep. :thumb:
  19. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I've applied it at work and at home.
    Not much different at work, although I do have a direct link onto a proper 50mb link to the internet (proper as in not cable, its a business leased line, fiber with an ethernet convertor on the end :baby:), and I've yet to test it properly at home, but I will!
  20. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    damn, much faster on 3.6.8, running on a 30Mbps down, 5Mbps up cable line
