Peripherals Firewire 800 - 400 adaptor?
Discussion in 'Hardware' started by bennifer, 15 Oct 2008.
  1. bennifer
    bennifer What's a Dremel?
    26 May 2004
    Hey, just got my new Macbook Pro today. Very very nice machine! It of course has changed to have only the firewire 800 port on the side. I've got a firewire 400 Presonus Firepod audio interface that I still need to use, was wondering if its possible to get a little converter dongley thing that plugs into my 800 port and lets you plug a standard 400 lead into it? Or anywhere that does cheap 800-400 leads?
    Cheers for any help!
  2. Nikumba
    Nikumba Minimodder
    29 Aug 2001
  3. bennifer
    26 May 2004
    Looks that way - how does firewire technology work then, do they just step down to 400 once you lose those 3 extra pins?
  4. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
    In Firewire, 2 pins are for power and power alone. That's why you see 4-pin and 6-pin Firewire400. The other 4 pins are the Firewire400 data pins, creating the IEEE1394a standard. In Firewire800/1600/3200, three more pins are added. When the pins are present (both devices are Firewire800/1600/3200), then the data is transferred at the faster speeds, depending on what chipset each side has, making IEEE1394b. Since the original 6 pins are still present, if the other three pins are not detected on either end, then it merely reverts back to the IEEE1394a standard. I'm sure someone can write a much more technical and detailed report, but that's the basics.
  5. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
  6. Firehed
    15 Feb 2004
    Basically, yeah. I don't think it's quite that simple, but using an 800-400 cable will allow the host to figure out what it needs to.
    I don't know if there's a UK equivalent of Monoprice, but if so that would be a good place to look.
  7. bennifer
    26 May 2004
    Cheers guys. Theres a few on ebuyer and amazon so i'll pop an order in tomorrow :) Its a shame there isnt just a little converter lead thing, as I have 5 or so 6-6pin leads that are now wasted...
  8. NoahFuLing
    18 Jun 2005
  9. bennifer
    26 May 2004
    ooh - just like those! any uk dealers that do them!?
  10. NoahFuLing
    18 Jun 2005
  11. Clipperz
    Clipperz What's a Dremel?
    17 Oct 2008
    Cool, did anyone take notice of this on the Shaggymac site:
    http://www.shaggymac.com/index.php?main_page=product_info&cPath=3_4&products_id=82
    The adapters will have to do for now. not as clean as I would prefer.
