Build Advice First build advice, thanks !
Discussion in 'Hardware' started by 70th, 11 May 2012.
  1. 70th
    70th What's a Dremel?
    11 May 2012
    Budget: £900 - £1000
    Main uses of intended build: Mainly playing Diablo 3, but also other games such as BF3.
    Parts required: Everything apart from Monitor
    Monitor resolution: 1080p
    Storage requirements: small SSD for windows and max of 500gb for everything else
    Will you be overclocking: yes
    Heres what I have as a build so far.
  2. Bede
    Bede Minimodder
    30 Sep 2007
    Change the Mushkin Chronos for a 128GB Crucial M4 - they're only around £20 more expensive and it's double the storage space. From personal experience, 60GB isn't enough.
    Change the Vengeance RAM to Vengeance Low Profile RAM - it won't fit under the cooler otherwise.
    I don't like the case, but a case is a completely personal choice so just make sure you like the one you're getting :)
  3. 70th
    11 May 2012
    Ok, thanks for the reply !
  4. javaman
    javaman May irritate Eyes
    10 May 2009
    Do you really need 16gb ram? for gaming 4gb is enough and personally I wouldn't go larger than 8gb.
    For gaming I would drop wireless and look into home plugs. Much more reliable connection.
    RAT is a claw style mouse, if it suits your style go for it. Im not fond of claw style (im better relaxed) but button placement felt very awkward on it and my friends one fell apart. I was looking at the saitek too but it didn't get great reviews. Eventually went with a logitech one a family member was throwing out. If you get a chance drop into your local PC store and see what they have. Try and think how you will play and what you've used previously.
  5. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    like bede said get lp ram. like poster above said, get 8gb you won't need 16gb
    like bede also said, your case is a bit ew, and probs doesn't perform well either
    in fact screw it, i was about to say get an m4 instead of your current ssd, but basically:
    what the guys above me said
  6. 70th
    11 May 2012
    Thanks for the reply, the PC will also be used for forensic programs which will utilize the higher amount of ram.
  7. javaman
    10 May 2009
    Oh and don't forget get windows 7 if you don't have a copy already.
  8. 70th
    11 May 2012
    What case would you recommend?
