Build Advice First Build - Slight Problems
Discussion in 'Hardware' started by aidacuk, 28 Apr 2011.
  1. aidacuk
    aidacuk What's a Dremel?
    27 Mar 2011
    Hi,
    I've just completed my first build :rock: (with lots of help from you guys) BUT when I turn it on it seems to turn itself off and on again a few times before loading the system. I'm not sure why but sometimes it works straight away, other times it boots about 5 times before loading.
    Also, the system is only registering 4GB of RAM, but I have installed 8GB (2x4GB). It says I have 8GB in the BIOS but on Windows it says I only have 3574MB of memory. Im running Windows Vista 32-bit, does this only accept 4GB?
    Do you guys know a simple fix to these problems? My head is still hurting from completing the build so I'm struggling to think straight at the moment!
    Thanks
  2. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Ok I'm not sure about your first problem, but yes you need a 64 bit operating system for the system to show and have useable more than 4Gb of ram
  3. aidacuk
    27 Mar 2011
    OK thanks, thats 1 problem solved :thumb:
  4. Seabrook
    Seabrook What's a Dremel?
    30 Mar 2011
    I have a similar issue to you whereas my computer will sometimes reset itself once or twice max before starting up properly. It only appears to do this when it's overclocked though, I'm not too concerned though about mine.
    I'm going to guess you have a similar build to me then, just without the windows 7 64 bit?
  5. aidacuk
    27 Mar 2011
    Yes pretty much the same, GTX 460 instead, also haven't OC'd anything yet.
  6. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    My brothers new i5 2500k build is doing those resets aswell! =O
    He is currently in the process of returning his mobo to asus for the B3 stepping upgrade at the moment though.
  7. Whindog
    Whindog What's a Dremel?
    16 Sep 2010
    I think the off on thing is the surge protection setting in the BIOS.
    I havnt tested it thou to confirm, but that seems to be what its doing. 5 times is unussual thou. Mine normally go on then off then boots properly, sometimes it does a second on off cycle.
    Not to concerned. As im pretty confident I know its the surge protection safety feature.
    Edit: Bindi might be able to confirm being an AUS rep and all ;)
  8. Guest-16
    Guest-16 Guest
    Things to check:
    Latest BIOS?
    What PSU and are you using and are all the connectors plugged in OK?
    Are you running from an extension cable or the wall socket - is the power and cable reliable?
    What slots are your memory placed in - the manual will tell you which are DIMM1/2. Leave your memory at the default 1333MHz for now. If your memory requires extra voltage, add it.
    Where does it reset exactly - does it POST then reset or do it before POST?
  9. Whindog
    16 Sep 2010
    Latest bios.
    All connections solid.
    I found on an Asus furom that it is an issue that will be addressed in the next bios update.
    Was on tweaktown under the asus section.
    Found that after writing that last post. Seems like it has somthing to do with unused drivers or the like
  10. Guest-16
    Guest-16 Guest
    Fair enough :)
  11. slothy89
    slothy89 MicroModder
    17 Feb 2011
    Im guessing it's non harmful? About to put together my i7 / P8p67 pro build next week when the CPU arrives.
    Dont want my AU$2.5k to go poof!
    Edit: any chance of a link to the thread at ASUS?
  12. Whindog
    16 Sep 2010
  13. slothy89
    17 Feb 2011
