Case Mod - In Progress First casemod: Project ROG Meets Lian Li - Lian Li A10B - Finished 30/5-12
Discussion in 'Project Logs' started by Cown, 4 Mar 2012.
  1. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks guys, glad you like it so far, I will have another update coming in a day or two :)
  2. Jamievs
    Jamievs What's a Dremel?
    16 Dec 2011
    Very inspiring!
  3. Cown
    Cown Minimodder
    25 Feb 2012
    Glad you like it :)
  4. Cown
    Cown Minimodder
    25 Feb 2012
    New stuff arrived
    Hey guys
    A small update on some stuff that arrived today, I plan on continuing the mod tomorrow :)
    Nice black PCI brackets from Lian Li:
    New PWM fans from Zaward:
    I'm hoping to get the window mod done this weekend as well, leaving only the front power/reset buttons to be finished :D but the new switches are currently out of stock :(
  5. Cown
    Cown Minimodder
    25 Feb 2012
    Update 30/3
    Time for another update :D
    It's time for the A.L.C to get modded a little:
    New fans installed, look pretty good if I may say so myself :)
    Mesh plates going to get pulled out for a paint job, unfortunately the front mesh was glued to the case, which was a real pain in the ***!
    Covered up and ready to get messy :D
    Done:
    Front mesh installed:
    Some pictures of the inside :)
    New PCI brackets installed:
    Top mesh:
    Some pictures of the case in different color settings:
    Up and running:
    Well I went a bit picture crazy back there, hope you can bare with me on that :D
    My daughter came in to help, or rather she wanted a "taste" for herself :D
    I think she approves :clap:
    Front in the dark:
    Now I only need to finish the window. I am going to get the plexi cut down to the right size tomorrow, and hopefully finish the mod :D
    To KΓλ©KΣΓ™, I've decided to leave the "strips" alone, because I think it does a good job of "braking" the colors and adding some more edge to the case, I think the full black to black would look strange and the red would be a bit too much, I like the simple lines :)
    As always, thanks for looking :)
    Waynio likes this.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Really nice modding mate, I like checking out first mods, reminds me of my first mods but mine were too bad to show with it all being experimental stuff done multiple times to my cases until they looked like they been through a war zone so ended up just looking bad :hehe: but this is far far nicer looking & totally presentable, guess it helps having so much inspiration around these days. :D
    I really like the cover piece you added to the cable mess area next to the mobo, really tidied it up, great stuff. :dremel::clap:
    stars & rep
  7. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Great work and you daughter is soooo cute
  8. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks a bunch mate, really glad you like it :D
    Thanks :D yeah I must admit she is adorable ^^
  9. Cown
    Cown Minimodder
    25 Feb 2012
    It's time for one of the final updates. I've completed my window mod and am nearing the finishing point of my casemod :)
    A few "quickies" before we continue:
    As you can se, I've moved the ATX connector behind the black plate I made earlier, getting rid of the somewhat messy cable management I had going on, I think it looks a lot better :)
    Oh well, we better get on with it!
    The plexi cut out in the right size:
    A small teaser on how it's going to look like:
    Measurements done, holes drilled and threads made the for the assembly:
    I plan on putting some insulation between the side plate and the plexi to avoid as much unnecessary dust as possible:
    On it goes:
    M3 screws from MDPC-X, I really love the quality of them, just superb:
    Window DONE!!!
    That's it for now, it's getting late here in Denmark and I'm getting tired :p I'll post pictures of the beast up and running tomorrow as well as some in the dark pictures :)
    As always, thanks for looking!!!
  10. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Simple and elegant... I like it a lot. :D
    One minor suggestion and it could very well be considered nit picking...
    See the bare edges on the window cutout? I'd "sharpie" those black to complete the black look.
  11. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks mate :)
    What do you mean by sharpie? I've used 1000 grit sandpaper to even out the edges, but the color doesn't go black :p so I'm guessing you mean something else :D
  12. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    A sharpie is a black permanent marker (sort sprittusch) to colour the grey/silver aluminum a nice solid black colour.
    It's a very nice mod made with simple materials. I approve!
  13. serjsorrow
    serjsorrow What's a Dremel?
    14 Aug 2011
    Very Nice work^^
  14. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Awesome, well done!
  15. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks for clearing that up :) I'll think of something :D
    Thanks guys :)
  16. Shurika
    Shurika Minimodder
    9 Mar 2012
    Cool mod!:rock: love the design! and idea with ROG image on the plexi is very cool:thumb:
    I don`t know how nVidia cards disassembling, but if top part of the cover could be removed what do you think about painting it in red?
  17. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks mate :)
    I plan on changing the 580 I have now to a 680 when it arrives, so it would be a waste, I an going to add a black backplate to the new card and maybe pimp the side with some red like you mentioned :)
    Sent from Bittech Android app
  18. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Considering you have a small amount of tools to work with, I think this is a great first mod. Nice work.
  19. Cown
    Cown Minimodder
    25 Feb 2012
    Update 2/4
    I've finally managed to take some pictures, and as you will probably notice, the edge of the window has changed color :D I need to find something that make the plexiglas plate less static, it simply sucks all the dust to its surface :( suggestions are very welcome :D
    Thanks for looking :)
  20. KidMod-Southpaw
    28 Sep 2010
    Looks fantastic and wonderfully clean, the only thing I don't like is the ROG logo on the window.
