Hardware First Look: AMD 790GX IGP and SB750
Discussion in 'Article Discussion' started by Guest-16, 6 Aug 2008.
  1. Guest-16
    Guest-16 Guest
  2. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    106,5 C :eeek: how long did it sit at that temp before you noticed and hit the big red STOP button to prevent it from a meltdown (was is the smell of frying chips that gave it away?)
  3. Guest-16
    Guest-16 Guest
    Long enough to hit print screen and need a change of underpants.
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    wow 106,5 C! And i get scared when my WC cooled 4800 goes to 35C
  5. bowman
    bowman Minimodder
    7 Apr 2008
    edit: Please disregard this post. Damn GPU nomenclature.
  6. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    i want one...
    seriously tho, all this talk of Nvidia scrappping their mobo division, how long before the NF200 chip ends up on boards like this so SLI can be done on anything like crossfire can?
    I want the SLI option, despite deliberately not buying SLI for my current machine, i feel the upgrade of a second 8800GT is the cost effective option i need, which means a new MOBO. So where to go?
    If they release SLI licence for this, then hands down, i'm sticking with AMD (have never bought an Intel chip).
    having said that, the 4870 looks good, if only Radeon cards didnt look so goddarn fisher price compared to Nvidia ones.
  7. Sebbo
    Sebbo What's a Dremel?
    28 May 2006
    well, its not an AMD board, but apparently some Intel X58 boards will have the NF200 chip
    any hint on when "very soon" is? between the 790FX/SB750 combo and the Phenom die shrink i'm really tempted to hold off on my (well overdue) upgrade
  8. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    106.5*C....
    can you make me a hard boiled egg please?
  9. Langer
    Langer Jesse Lang
    24 Jan 2004
    Sounds promising... I knew AMD would be back eventually; this looks like they are on the right path.
    Any idea of when will I be able to sink my teeth into a board from ASUS?
  10. Jasio
    Jasio Made in Canada
    27 Jun 2008
    AMD's chipset division has always been an under-dog of sorts.. but they've consistently delivered good quality products, maybe not the fastest, but lots of good experience, no compatibility issues and their mATX mobo's are great for HTPC's and single CPU server solutions where space is an issue. My choice of chipsets has lately been Intel > AMD > nVidia. Though with Hybrid-CrossFire, as an HTPC solution I'd take AMD over Intel.
  11. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I've been waiting for these new boards for over a month now. Where are they? :p
Tags: Add Tags
