Hardware First Look: Asus Rampage III Gene, Quad SLI, Ares HD 5970
Discussion in 'Article Discussion' started by Sifter3000, 28 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Hmmmm mATX goodness!
    :D
  3. lacuna
    lacuna Minimodder
    9 Aug 2004
    Well, the card does look nice I suppose...
  4. capnPedro
    11 Apr 2007
    :rolleyes:
    Considering the quite considerable amount of modding required to then get the cards to fit into a case, the only people I can see using this s hardcore benchers, but they'll scoff at the 1-2% performance loss!
    This daughterboard is kinda crazy. Crazy as in there isn't a special revision of the board with it built in instead!
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Motherboard's looking quite good. The card I'm not impressed by, but like lacuna said, looks nice.
  6. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    What i dont get about the super ultra mega foursome duahgterboard is that there are boards that feature 4 PCIe slots that can fit in cases and dont require you to spend yet more money on an already crazy expensive board.
  7. wyx087
    15 Aug 2007
    i don't think they've got a large enough cooling block on that 5970 :D
    wonder when we'll see special cases designed for this kind of riser board, and by which brand.
  8. douglatins
    douglatins What's a Dremel?
    28 Nov 2009
    They already lost with the ARES, Sapphire have a better solution. Also i have quality concerns for the ARES. Looks bad
  9. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Unless that type of board becomes commonplace, never? I wouldnt have thought it would be viable for case makers to cater to the 1% of people that would need such a case.
    So that leaves ASUS building their own cases to fit their own board, and the last ASUS case i saw, looked like it fell out the fugly tree and hit every branch on the way down!
  10. douglatins
    28 Nov 2009
    ASUS Should boundle the ROG thing with riser brackets for PCI holders
  11. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    You'd still have issues with connectors fitting
  12. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    What is the build process of the NF200? Probably it's not 45 nm...
    Since they can't make chipsets anymore, why doesn't nvidia make a "NF300" that addresses the performance, heat and power consumption issues?
  13. -VK-
    -VK- Lurker
    11 Oct 2007
    Um - Any facts to back that up?
  14. Nature
    Nature Minimodder
    21 Nov 2005
    "If you think this kind of aggressively styled hyper card tomfoolery is for you then we’d recommend you start looking in to ways of flogging a kidney or your first born given the exuberant estimated price tag of around £1,000."
    Why not the kidney's of your first born?
  15. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Good idea in theory. Completely retarded in execution.
  16. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Oh hai! Lookie here what I've got :D
  17. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
    Surely the 'extreme benchmarker' that the daughterboard's aimed at won't care about its inability to fit in a case as they'll just be using a bench? But then again, if I wanted quad cards, I'd have bought a board that supports them in the 1st place.
  18. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I wonder if you could put a ribbon PCI-E cable to the other two PCI-E slots covered by the daughter board and then have two daughter boards installed for 8 Graphics cards, pop in some GTX260 and that could be a kiler Folding@Home rig, pop GTX480 and well we get to see rolling blackouts and a possible global temp rise of 10 degrees ending all life lol....
  19. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Don't start giving Asus more crazy ideas
  20. docodine
    docodine killed a guy once
    10 Feb 2007
    Asus's craziest daughterboard since the thing their Pentium M to Pentium IV adapter :eek:
Tags: Add Tags
