Hardware First Look: ATI Radeon HD 3450, 3470 & 3650
Discussion in 'Article Discussion' started by Tim S, 23 Jan 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    Wow. All those cards look small! (PCB wise)
    Look like they are all gunning for HTPC or simple desktop use.
  3. naokaji
    naokaji whatever
    8 Dec 2006
    displayport and hdmi are still a big lie. only one of the cards pictured has one of those fancy nextgen connectors....
  4. Tim S
    Tim S OG
    8 Nov 2001
    HDMI is supported through a dongle that is supplied in the box and DisplayPort is added on a per-SKU basis (because of its lack of prominence in the market at the moment) - I'm pretty sure I mentioned both in the article. :worried:
  5. naokaji
    naokaji whatever
    8 Dec 2006
    true,
    but after all that marketing hype surrounding both connectors i was expecting a far more aggressive approach to get them implemented straight on the back of the cards.
  6. Tim S
    Tim S OG
    8 Nov 2001
    sure, but then what happens when someone with a DVI display wants to connect their monitor? Most people have DVI monitors, so it makes sense to keep dual DVI for the time being on the 3650 and DVI/VGA on the lower-end cards because they're taylored more to the value segment. That said, I want to see VGA disappear of these cards and be replaced by either HDMI or DisplayPort.
  7. Lukeatluke
    Lukeatluke What's a Dremel?
    27 Dec 2007
    VGA will disappear soon, DVItoVGA connector are available but for the fact more than 95% people are using DVI and VGA displays :cooldude:
  8. p3n
    p3n What's a Dremel?
    31 Jan 2002
    95% of statistics are made up on the spot :p
  9. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    What I wanted to see was details on the 3870 X2, Tomshardware (I only check it once every couple of weeks) had an article on it and I got to page 5 (of 19) before they pulled it - the title looked promising though.
  10. Tim S
    Tim S OG
    8 Nov 2001
    Yes - it's big and red. ;)
  11. Tyinsar
    26 Jul 2006
    Cryptic eh? When might that be announced? Or would the NDA not allow you to disclose that? What does the average NDA allow & disallow? - Can you say: if you're under NDA, what you're under NDA for, when the NDA comes off, ...?
  12. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    there is a chinese review out on xtremesystems somewhere that shows it outperforms the ultra in everything bar crysis (badly optimised for xfire apparently)
  13. naokaji
    naokaji whatever
    8 Dec 2006
    heavily depends on the nda... some nda's even forbid you to mention the existance of the nda, while others say you can only publish preaproved info, some say only pictures no benches or whatever the marketing department of a company comes up with.
    I'm pretty sure that it would be possible to have a dvi and both hdmi and displayport connector on the back of a single slot card.
  14. completemadness
    completemadness What's a Dremel?
    11 May 2007
    why do all the slides say "confidential" :eek:
  15. Tim S
    Tim S OG
    8 Nov 2001
    Because they were confidential until AMD removed the embargo today. :)
  16. Amon
    Amon inch-perfect
    1 Jun 2007
    These will work nicely in laptops for sure. Great bargain, too!
  17. wyx087
    15 Aug 2007
    not sure about GDDR2 with 512MB of vRAM..........
    but i want to see how well it performs for price/performance with 9600GT, i need a backup PCIe card, hoping to get a PCIe2.0 card before 9800GTX comes out, so i won't loose so much money. and pricing at £50, looks just to be the perfect card to use as i stepping stone
  18. tk421
    tk421 Idiot.
    15 Jan 2002
    that half height 3450 with hdmi really screams "make the gx280 a media server" to me ...
  19. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    I can understand the purpose of the 3450, it would make a great media centre card, but why the hell are they releasing three low end cards, its hardly like the 3850 and 3870 are top-end cards. They have absolutely nothing at the top end of the performance market.
  20. Tyinsar
    26 Jul 2006
    Actually if it wasn't for the 8800GT the 3850 & 3870 would be the best price / performance cards - even now they could be, depending on cost, it's a close call.
Tags: Add Tags
